any suggestion
Good luck...the only company that I have found that makes one for the cobalt is SPEC...and of all of theirs the best one is the stage3+...anything else will probably be a bit quick to grab.... If you are use to an aftermarket clutch then you might get by with a stage 2+....
bc spec = phail
i don't like spec bc they have a tendency to explode... i've heard that from many a fellow w/ spec clutches...
why doesn't the centerforce dfx work w/ the lnf balt?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
