ATI damper with F40 swap
Old Aug 2, 2020 | 11:12 PM
AG305's Avatar
so im currently in the process of installing cams, nbs and an ati damper on my lnf and was wondering if you guys knew if there is or can be any fitment issues expected with the damper. its being installed while still using an F35 trans however i will be swapping to an F40 shortly after.
my main concern is since the F40 swap tends to push the engine more towards the passenger side, will there be an issue with the ati damper hitting/rubbing something or not fitting?
what have you guys that are running F40s with one of these dampers done? whats expected/what can i look forward too later? is there something i can or should do while im down there installing the damper now before i swap to the F40?
any and all help is appreciated. thanks!
LNFwagonSS
Sep 29, 2015 09:04 AM
patooyee
Aug 9, 2014 01:11 PM
ben_gary
Oct 2, 2012 02:59 PM
riceburner
Jan 3, 2012 09:31 AM
Tinkles
Nov 1, 2011 10:36 PM
