Back to ZZP for round 2!
Old Apr 10, 2012 | 02:11 PM
cobaltssoverbooster's Avatar
did they send a dyno graph we can see id like to see the 5th injector dyno graph pretty please 8D
Old Apr 11, 2012 | 12:36 PM
Boosted06SS's Avatar
I tried to post this up but it was small, when enlarged it became blurry.
Old Apr 11, 2012 | 04:39 PM
Matt M's Avatar
I will post up the charts tonight.
Old Apr 11, 2012 | 09:45 PM
Matt M's Avatar
The first chart is 3 different boost levels- 23, 25.5, and 28psi. No tuning changes were made between pulls. You can see the dyno pull times with less than 3 minutes between the 2nd and 3rd pull.
The 2nd chart shows the max power achieved on the large fuel pump lobe with E85 that tested at 82%E. It also shows the highest hp pull we did on this car with the addition of the lnf5 5th injector kit. There was still quite a bit of fuel system to spare, but we surpassed 500whp and didn't see any reason to push a customer's car further.
There is no afr on this dyno sheet because the first test did not have the wideband scaled for E85 and the last one did. I just wanted to avoid the inevitable questions as to why the afr is so much different between the two.
Old Apr 11, 2012 | 11:20 PM
Frogstofall's Avatar
Thanks for sharing Matt.
Old Apr 12, 2012 | 12:20 AM
raver0789's Avatar
Stupid question Matt M - why do u cut their rpms off at 6900? I was planning on running ur turbo to 7500 with valvesprings. Wouldn't hp still be increasing beyond 6900 and quite a fair bit?
Just wondering.
Old Apr 12, 2012 | 08:47 AM
Matt M's Avatar
Just wondering.
On Mustang dynos, you set the test window before making a pull. It's nice for tuning since you can compare averages without having the variable of where you let off. Yes, we could have made a little more power by running the test out further, but we got enough data to make a nice comparison and complete the tuning. A setup like this should be shifted at 7200 RPM because we can only control the cams up to 7400, where hp drops quickly.
Old Apr 12, 2012 | 09:08 PM
Joe Schulte's Avatar
Awesome, those are some #'s to be REAL proud of!
Old Apr 13, 2012 | 02:04 PM
Cobe's Avatar
Hell yeah dude
Old Apr 13, 2012 | 02:40 PM
Fastgti69's Avatar
awesome numbers. I can't wait to go BT. ****!
Old Apr 14, 2012 | 10:27 PM
  #36
raver0789's Avatar
Was this done with a .55 AR or was it a larger one like a .70?
Old Apr 15, 2012 | 01:13 PM
  #37
Matt M's Avatar
.55
Old Apr 15, 2012 | 01:28 PM
  #38
JacBlackSS/TC's Avatar
what does zzp charge for labor thinking about sending you guys my car
Old Apr 16, 2012 | 06:18 PM
  #39
You can check thier site, I believe they have the rates. I would just email them and find out more.
bigdeertz
Nov 17, 2016 09:41 AM
How to Guide
57
Oct 15, 2015 11:56 AM
Supercharged06SS
Oct 5, 2015 09:13 PM
DocSvensk
Sep 27, 2015 02:24 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
