Big boom
Old Jan 10, 2011 | 10:23 PM
slowstang's Avatar
Originally Posted by 2010SS
So... Got the bumper off... And that "boom" was the ic... Whole big enough to put my fist thru... I have a zzp goin on right now... Pics later... I'm only running 21-22 psi... Guess the cold got to it
Welcome to the club
Old Jan 10, 2011 | 11:09 PM
tomj77's Avatar
im glade i bought my zzp, everyone should replace the stocker, i dont like the idea of haveing plastic anything on my intake system
Old Jan 11, 2011 | 12:21 AM
RyRidesMotox's Avatar
The cold and/or any rubbing of the condensation bar on curbs or anything really, snow, your ex-girlfriend that you ran over last week... Any moving of the IC like that will cause stress on the end tanks.
Old Jan 11, 2011 | 02:37 AM
MajorCB's Avatar
So, while driving a few minutes ago , shifting from 2nd to 3rd I hear a huge boom... Car goes into limp mode and that's all... Theories are cracked ic blown charge pipe (don't think it's this as I checked) or blown cat... Really have no idea but never heard that noise before... CEO came on a while later I will scan in the morning... Thoughts??
one thing I think we tend to overlook sometimes, whether we think about it or not.. is the weather... if its really cold out, all that plastic tends to tighten up.. connection ends, piping, etc, even if you let the car "warm up" the difference in temperature can sometimes have an effect when things are expanding fast... so you "may" have had some thermal breakdown, being as you are from Maryland, and its been pretty darn cold, under higher boost it could have caused a failure if there was a pre-existing weakness in the internal structures of the piping, metal to plastic components or whatever... just another consideration but one I think sometimes is overlooked as a possibility. Just my two cents...
Old Jan 11, 2011 | 12:32 PM
2010SS's Avatar
ZZP IC vs POS IC
installed ZZP charge pipe
Old Jan 11, 2011 | 02:45 PM
CudaJoe's Avatar
ZZP IC vs POS IC
Any pieces of plastic get in the intake system?
That ZZP charge pipe is a nice solid piece, not sure why people over look it when buying a charge pipe?
Did you buy couplers or take apart the stockers?
Old Jan 11, 2011 | 03:34 PM
2010SS's Avatar
Nothing in the intake. Used the stock couplers and yes it is... Looks good and fits good , I likethat it's plain looking
Old Jan 12, 2011 | 12:45 AM
LittleRedRocketSS's Avatar
very nice .... i had just got replacing mine sunday night when i blew it saturday night ughh such a pain in the butt replacing....
Old Jan 12, 2011 | 01:06 AM
2010SS's Avatar
Yup, it was a process... On my test drive after putting it backtogether... I saw a crashed up white as turbo... Put a damper on the night
Old Jan 12, 2011 | 03:41 AM
That is a big ass hole in that end tank... Guinness book of records big damn... At least nothing got sucked into the rest of the intake path.
Old Jan 12, 2011 | 10:16 AM
  #36
wantedSS/TC's Avatar
Not THAT big. It's eerily similar to my blowout however:
Old Jan 12, 2011 | 10:21 AM
  #37
2010SS's Avatar
Holy crap that does look exactly the same. I even have the se crack across the front
Old Jan 12, 2011 | 10:42 AM
  #38
That's why I went when I saw yours. We had the same blowout basically.
Old Jan 12, 2011 | 10:51 AM
  #39
2010SS's Avatar
what were you doing when it blew? like driving normal or aggressively? mine blew shifting to 3rd
Old Jan 12, 2011 | 11:06 AM
  #40
Mine blew on a 3rd gear pull. A BOOM followed by a couple backfires, low oil pressure light and a flat bed later and I was home. Car would start and then die. The shitty thing is; I was a mile and a half from home. Go figure.
Old Jan 12, 2011 | 11:09 AM
  #41
2010SS's Avatar
wow thats crazy, my car ran fine, (minus the 50 hp it had) and i drove it home pretty far, i was scared too but it wasnt showing any signs of worsening problems
Old Jan 12, 2011 | 12:15 PM
  #42
MajorCB's Avatar
I wonder if there is an outstanding or inherent weakness in this design then perhaps if this location seems to be the "weak point" for blow outs... hmmm makes for a good case to upgrade right away, especially if you live in colder climates.. or for those who just can't keep their foots off the gas in the cold!
Old Jan 12, 2011 | 12:39 PM
  #43
Grishbok's Avatar
That point is the highest pressure point in the IC design. Looks like a combo between the pressure and cold weather tightening up the plastic. That is what I'd expect to see torture testing an IC. Kinda like dumping boiling water on a frozen glass, the contrasting temperatures put serious stress on plastic, combined with the psi, kaboom. You can get the same effect with metal end tanks along the welds.
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
