Big Turbo Coolant/Oil line install
Okay the lines are all hooked up. Now i got some vacuum caps for the by pass system on the intake mani fold. Is that what you guys did? What did you do to block the lower charge pipe nipple off. I have a zzp lower charge pipe
If your controlling boost with the ecu just cap off the bpv port and leave the rest like stock. T the bov into the line going right to the manifold. Sorry I don't give my number out. Done it one too many times and had one to many people burn me for information and calling me at 1-2am. So I'm not doing it anymore.
#36
#38
Personally, I would remove the bpv solenoid and all it's lines as a whole. Then just cap the nipple on the lower charge pipe, and run the vac/boost line direct from the manifold port to the bov. No need for any T's in the system at that point and it cleans up the engine bay of items that are just simply not needed.
#39
#41
Okay so since im physically not at my car thats why i ask all these questions now lol. But i have it figured out. Intake mani to bov. cap lower charge pipe. Take off tank underneath car. Good to go lol. But what does the sensor connect to? Sorry not at my car lol. Will it throw a code or light?
#42
Cap the bov port and leave everything else alone. Leave the line that goes down to the charge pipe from the solenoid too. Idk why your trying to cap it.
If your deleting the vacuum tank all your going to do is not take the line off the manifold and the line off the solenoid and run a line from the solenoid directly to the manifold. Then you will splice a t into that line.
#43
