Big Turbo Stock Motor?
Old Sep 20, 2017 | 04:31 PM
double clutch's Avatar
Interesting. Ill have to see what the deal is with those.
I am sure I will get bored of my setup eventually, and will want to push it harder. I can even go to zzp's magic dyno to see if that makes a difference.
Old Sep 20, 2017 | 04:33 PM
I have a feeling unless you get tuned by them you won't be experiencing the magic
Old Sep 20, 2017 | 05:41 PM
63 Nova SS's Avatar
I'm pretty sure 09CobaltSS1 (John) made around 470hp with a 5th injector on a stock motor. But alas he is a tuner. Believe it was on e47. It's not 500 but not far from it. Stock cams I believe.
Old Sep 29, 2017 | 07:12 PM
tomj77's Avatar
I was on stock motor zfr 27lbs boost. Little over 400whp. No issues. Till turbo went and I did a ldk build
Old Sep 29, 2017 | 10:17 PM
63 Nova SS's Avatar
So was John, but he had e47 on his side.
Old Sep 30, 2017 | 12:53 AM
cw383's Avatar
The stage 3's had the same lift and duration as the stage 2's, but they were clocked different. They were not recommended for street use, but sure sounded good.
Originally Posted by ECaulk
They made some stage 3 cams for a bit, he found them used (well not really used I don't think the previous owner installed them) you might be able to contact them about them, but I'm fairly certain they stopped offering them. Why idk
Old Sep 30, 2017 | 10:04 AM
Oh, well that is reasonable why they don't make them anymore. Given most people daily their cobalts not racecar
