BigBoost954 Motor build
Someone's a hater.
Pretty sure he meant to say stock trans instead of stock turbo cause he did have a wr3 producing those numbers. Its the torque that breaks the trans. It spools too quick for its own good. Ask me how I know.
Lol no hater but with the damage it causes and it's limited potential I'd say there are better options
Yes stock trans has taken a lot of abuse. I know that will be the next part that I buy. No offense taken, I have been through a build quite similar and put out some pretty good numbers on only 93. I beat the **** out of my 3.83 with the wr3 and it will take even more abuse (mostly track) with the 6258 on e85. We shall see how long she lasts haha
^ Well that didn't work. Must not be true. Boom at 6k
http://s1189.photobucket.com/user/ra...ml?sort=3&o=11
Yeah you could be right. I just think its not necessarily a certain amount of quick power. Its stress along the powerband. The zfr is lethal not just because of quick spool. It can put near 400wtq over a huge range...
It wouldn't make 530ish around 8k. Gains are diminishing the higher you rev. I think after 7.5k the s256et runs out of steam to hold 29psi to 8k. I would expect power to fall off.
See this:
http://s1189.photobucket.com/user/ra...c1851.jpg.html
See this:
See this:
See this:
355/5252*7350=496.8
Yeah it's not dead on, I'm guessing numbers on a broad graph. But that equation always holds true.
Tq*rpm/5252=HP
Ever notice tq and hp always cross at 5252rpm? That's why.
Lol...yeah around there...anywhere between 355 and 370 at 7400.
Good scientific explanation lol.
I have discovered this is was with a huge exhaust leak, and a wrong wastegate spring. Torque should have been 460ish at 4k.
I'm wondering how that will change the whole curve.
Manifold leak or post turbo?
Realistically it should shift the whole curve straight up but still fall towards te end.
I realize it'd take one healthy snail to maintain a flat tq all the way out. But one can always dream...
i was thinking bout running that controller but, it only goes to 30psi, decided to go with AMS400 i was also looking at a 20lb spring for my turbosmart but i think maybe a 15-18lb spring would be ok
There is an add on that let's you run up to 99 psi or something crazy.
NM 5 bar
http://www.aemelectronics.com/tru-boost-5-bar-external-sensor-upgrade-758?osCsid=kucd8q72ag6ns3nvdcfh6qekh3
In my opinion from running it you can control duty cycle on it to exceed 29psi. But after ~31psi your boost will not accurately read without the upgrade.
I like how I can switch between two boost levels on the fly or you can scramble boost if you are a crazy ****. Things I dislike - it works off duty cycle and depending on the day your boost levels are not the same everyday. You'd have to do fine adjustments everyday to get specifically the boost you are looking for.
One day boosting 26psi. The next day 25..that sorta thing.
Setting the wastegate spring crack pressure too high makes the car drive weird. Hence choosing a bigger spring.
NM 5 bar
Ok def sumtin for me.to look into, I dnt want to kick.out 600 for the turbosmart and the AMS500 is just bad ass like the two stage feature ramp boost featurespriced well monitors up to 41psi
ThoR294
Oct 4, 2015 08:44 PM
