Blow by? or turbo seals
Old Feb 18, 2011 | 11:19 PM
Boogie_69's Avatar
I recently had a retune to 24lbs on the car. I put in new stock plugs and last night, noticed the car was idling a lil funny. Well after further review of driving down the road, i noticed smoke coming out the exhaust after the turbo spooled. Idling and driving out of boost, there is no smoke, but after boost, white smoke comes out the exhaust. Tonight i took out the plugs i just put in and noticed the #4 cylinder plug was black as all the others are white. Any info as to what the problem may be would be greatly appreciated. I have pic but am unable to post them in the thread
Old Feb 18, 2011 | 11:47 PM
YelloEye's Avatar
Oil should be dark grey or blue smoke, fuel is blue smoke and water is white.
Old Feb 18, 2011 | 11:53 PM
FrossB's Avatar
Thread Killer
Well mine had the same exact same problem..and white (more white than any other color) came from the exhaust..and i was told it was my turbo seals...so i bought a new turbo and swapped it out and it runs like a charm..no more smoke!
So assuming you diagnosed the vapor-ish substance correctly..and know its smoke (smell is another give away) then i would say turbo seals
Old Feb 19, 2011 | 12:49 AM
Boogie_69's Avatar
Would injector seals be a problems well or that would be a constant smoke rather than just under boost
Old Feb 19, 2011 | 02:36 AM
silverbullet08's Avatar
Did you recently change your oiL? One time i added a little too much oil on my oil change and the car white and blue smoked after getting on it when i came to a stop. It was just blowby but had the same symptoms your having. just a thought
Old Feb 19, 2011 | 08:50 AM
Iam Broke's Avatar
Injector seals leaking will give you a fuel smell under the hood and low compression, not smoke in the exhaust.
Old Feb 19, 2011 | 09:46 AM
Boogie_69's Avatar
well the smoke comes out when I release the gas pedal and being under boost. But I also have the problem of having a choppy idle as well the number four spark plug having oil on the tip of it. All other plugs were fine.
Old Feb 19, 2011 | 12:43 PM
ring going out? id take that in for warranty. if it was the turbo leaking oil you would have oil on every plug. a single plug means there is something wrong with that individual cylinder. Bet its a cracked ring... Prolly going to let loose any day now. Id take it in asap before more damage is caused.
You can try a compression test on that cylinder. See if it leaks down any after a 5-10min wait. plus cylinder pressure should be about 160 so if four is lower than the others youll know for sure
Edit: just read your mod list.... almost guarantee you its a ring. Your using infiniboost... What boost did you request or are you running? 28-29psi?? That tune creates so much heat with our small turbos it will stir up all sorts of problems. If it was your turbo u wouldnt be able to boost corectly. probably low or no boost at all.
Old Feb 19, 2011 | 12:48 PM
094doorSS/TC's Avatar
fuel is black smoke.
Old Feb 19, 2011 | 01:36 PM
Boogie_69's Avatar
It was set on 27lbs for a while and was recently changed to 24. But If it was a cracked ring, wouldn't it constantly smoke whether in or out of boost
Old Feb 20, 2011 | 06:30 AM
Boogie_69's Avatar
Done a compression test last night and revealed that cylinder four was around 75-80 lbs where as all other cylinders were showing between 150 and 160. When number four plug was pulled, no oil or any residue for that matter was on it. But there hasn't been any boost to that car since they were installed, so looks like it is one of the rings or ringlads.
Old Feb 21, 2011 | 02:17 AM
gtsr100's Avatar
well kinda in the same boat but my motor is already apart at gm and getting fix under warrnty mine was oil blow by witched cause my valves not to close fully. number 3 was sitting at 40psi the res where at 140 psi all the car would do is missfire all over the place sucks but getting fixed and waiting for the exhust valves now
Old Feb 23, 2011 | 06:51 PM
Boogie_69's Avatar
Did the dealer give u a run around as far as warranty work. They tried to say I had tons of aftermarket stuff under the hood, all thats there is charge piping and k&n intake.
Old Feb 23, 2011 | 09:13 PM
gtsr100's Avatar
No the service writer and all the techs are good friends so GM knows are motors have bad vavle. Seat problems
Old Feb 23, 2011 | 09:16 PM
boost_junkie16's Avatar
Glad someone else picked up on that as well
Blue = Oil
White = Coolant
Black = Fuel
Old Feb 23, 2011 | 09:39 PM
Boogie_69's Avatar
i believe the dealer i took mine to just doesnt want to do the work, any recommendations?
Old Feb 24, 2011 | 04:35 PM
gtsr100's Avatar
Return it to stock and take it some where eles play dumb with them
Old Feb 24, 2011 | 05:06 PM
DillySS's Avatar
Take it all off and go to another dealer
Old Feb 24, 2011 | 11:24 PM
YelloEye's Avatar
Blue = Oil
White = Coolant
Black = Fuel
Thanks guys, long night at work that day I think
Old Mar 9, 2011 | 09:17 PM
Boogie_69's Avatar
took the balt to where it was originally purchased, got motor replaced and picking up tommorow. They said it was a valve but if they just fixed the head, they figured i would run into problems later on down the road so they just replaced the whole engine.
Old Mar 10, 2011 | 10:27 AM
cubaniche's Avatar
Great news! Glad to hear you will back on the road soon. Just remember if you tune it again do not go over 24psi. In fact Id probably see if you can run just a tad bit more timing and lower boost to 22.
Supercharged06SS
Dec 11, 2022 04:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
maliki778
Oct 1, 2015 07:39 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Trav3480
Sep 28, 2015 02:46 PM
