Blowby?
Old May 24, 2012 | 08:24 AM
user 72239's Avatar
Blowby?
So my car was needing an oil change, and I decided it was a good time to seafoam it.
I put some seafoam in the car, drove it for about 3-4 days and then changed the oil. I noticed that the oil smelled like gas, but figured it was due to the seafoam.
I put new oil in and a few days later pulled my dipstick out and it smells like gas too. Are my piston rings fried? The car drives fine and I get no smoke coming out the muffler at all.
Btw I use Mobil 1 5W-30 full synthetic.
Old May 24, 2012 | 11:10 AM
tomj77's Avatar
Check compression. My catchcan fluid, when I got lots of condensation in there last winter smelled a little gasy to, but my oil doesn't, could be u do or it could be just fumes causing the oil to smell. Check it out
Old May 24, 2012 | 11:12 AM
thebucky84's Avatar
compression test or leak down test will let you know real quick
Old May 24, 2012 | 05:14 PM
peachpuff's Avatar
That's normal, the rings aren't perfect seals.
Old May 24, 2012 | 05:29 PM
vahdyx's Avatar
Who tuned your car?
Old May 25, 2012 | 02:32 PM
Shanedude's Avatar
Subd. Seafoam was hyped here for awile. But recently read threads on another site about NOT seafoaming LNF'S. Have a can sitting in my house not sure to use it or not...Where's that guy(rukkee?) who was doing it every 5-10k at and how is his car holding up?
Old May 29, 2012 | 08:19 AM
user 72239's Avatar
Originally Posted by vahdyx
Who tuned your car?
Car isnt tuned, its stock. I've been wanting to get a tune, I just got back from New Mexico so I'll do a compression test when I get home
Old May 29, 2012 | 08:34 AM
FrossB's Avatar
Thread Killer
threadjack...i was just in New Mexico too lol
/endthreadjack
Old May 29, 2012 | 09:07 AM
user 72239's Avatar
/endthreadjack
It was windy as **** there, blowing my car all over the place lol.
Old Jun 16, 2012 | 04:31 PM
user 72239's Avatar
Did my compression test finally.
Cylinder 1:125
Cylinder 2:125
Cylinder 3:130
Cylinder 4:125
Pretty much the same across the board. I'm not burning oil, and while that seems low I do live 5500+ feet above sea level.
Old Jun 16, 2012 | 04:38 PM
nhanson's Avatar
Pretty normal. Cold starts have lots a blowby so gas will get into oil.
Just dont get on the car till like 150+ coolant temp
Old Jun 16, 2012 | 04:55 PM
cmiller8006's Avatar
Compression test on my car was normal, leakdown all between 4-6% and my oil smells like gas every oil change. Like said the rings dont seal perfectly and on start up you get some blowby. My car burns 0 oil so I call it good. Also when you are pushing alot of air in there you are going to get blowby no matter what.
Old Jun 16, 2012 | 04:59 PM
FF_ace's Avatar
Havnt done a leak down test but after my build compression test was 165 across all 4 cylinders. I burn a lil oil about 1/2 qt
Old Jun 16, 2012 | 05:41 PM
user 72239's Avatar
Compression test on my car was normal, leakdown all between 4-6% and my oil smells like gas every oil change. Like said the rings dont seal perfectly and on start up you get some blowby. My car burns 0 oil so I call it good. Also when you are pushing alot of air in there you are going to get blowby .
Well that's good. I guess I was just being paranoid.
Old Jun 16, 2012 | 06:10 PM
09CobaltSS1's Avatar
I seafoam mine just about every oil change, but only through the vac line in the manifold (not in the oil or gas tank) and the car has been great. I plan on taking off the manifold sometime soon to have a look in there to see if it's actually been doing its job or not so we'll see. I'm personally not really a big fan of dumping anything in the oil that can thin it out further unless it's for a VERY brief period and only as a flush, but I know seafoam claims otherwise.
Old Jun 17, 2012 | 12:09 AM
Ch1ck3n's Avatar
LNF's are notorious for fuel contamination in the oil. My car has been doing that since I bought it with 9,000 miles. 30k later and it still does it and runs perfect.
Old Jun 17, 2012 | 01:05 AM
Maven's Avatar
if it smells strongly of fuel you should take the dipstick out and let place a drop of oil on a paper towel....if the there is a ring of fluid that quickly flows out into the towel while the oil droplet flows slowly then you likely have too much fuel in the oil. Get a used oil analysis and be sure, or pull your HPFP and make sure its not leaking internally. When they do they just dump raw gas into the oil. Becoming a fairly common.
Turbo Johnny
Feb 21, 2019 09:41 AM
Turbo Johnny
Jun 27, 2015 03:09 PM
07BaltSS/SC
Mar 26, 2009 10:21 PM
BrianJHoov
Oct 1, 2006 10:11 PM
