BNR losing boost top end
Old Mar 14, 2012 | 09:40 PM
Dart_SI's Avatar
http://www.youtube.com/watch?v=NMi4HmpULyg
So I got the bnr tuned. I like it but at about 5500 boost falls from 26-27 to 20. Its also a little slow on spooling.
What could it be from? Should I put more preload on the wga? I want that top end!
Old Mar 14, 2012 | 09:47 PM
donkeyballs's Avatar
That dam 30psi tune killed your **** You sure you don't have any boost leaks?
Old Mar 14, 2012 | 09:52 PM
Dart_SI's Avatar
Ill have to check. The thing is it holds 26 psi for a bit, then tapers to 20.
Old Mar 14, 2012 | 09:54 PM
CCrunner84's Avatar
What'd the tuner have to say about the noise? That didn't sound right, could be the wastegate like you had mentioned, may attribute to the noise you've been hearing too.
Old Mar 14, 2012 | 09:57 PM
Dart_SI's Avatar
He didn't say anything. Lol. I was his first turbo swapped lnf. He's a fantastic tuned tho.
Old Mar 14, 2012 | 10:01 PM
CCrunner84's Avatar
I'm no turbo expert, and don't want to act like one, but I'd maybe forward that video to whoever made the turbo and ask for their opinion, it wouldn't hurt.
Old Mar 14, 2012 | 10:03 PM
Dart_SI's Avatar
Yea ill do that tomorrow.
My tuner said an mbc could help too.
Old Mar 14, 2012 | 10:16 PM
shiftingloco310's Avatar
hopefully everything works out for you man. I have my bnr2871 sitting in a box waiting to be installed. i'm trying to get as much info before i put this turbo on.
Old Mar 14, 2012 | 10:20 PM
brant's Avatar
k heres the solution... mbc.. the stock solenoid is garbage when i swap 58/57 my boost was fine then it started tapering off from 24psi-20 a wot .. went to mbc no more issues
Old Mar 14, 2012 | 10:24 PM
blrt's Avatar
This sounds like a characteristic of a smaller turbo? Quick spool but won't hold high psi up top?
Old Mar 14, 2012 | 10:34 PM
Dart_SI's Avatar
Ill try that. Hope it works, I have no top end.
This turbo has proven to hold up to 6700 or so with only like 1-2 psi drop, not 5-6
Old Mar 14, 2012 | 11:00 PM
Dart_SI's Avatar
bump for more help. OP updated with a video.
Old Mar 14, 2012 | 11:02 PM
brant's Avatar
lol try the mbc.. lol that exactly what happened to me
Old Mar 14, 2012 | 11:09 PM
Dart_SI's Avatar
hope your right, this is frustrating. lol
Old Mar 15, 2012 | 02:24 AM
Fastgti69's Avatar
**** looks like it moves tho.. That speedo isnt lying ..
Old Mar 15, 2012 | 05:16 PM
Ch1ck3n's Avatar
Even though it's dropping in boost, it's definitely moving more air than the stock turbo. The tiny stock turbine/housing is going to choke up on the top end, no way around it except a bigger one.
Old Mar 15, 2012 | 05:22 PM
Dart_SI's Avatar
It is a bigger one. The BNR has a gt2871r compressor housing. Its plenty bigger than the k04 one.
Old Mar 15, 2012 | 05:31 PM
vahdyx's Avatar
Sorry have to ask, what's MBC?
Old Mar 15, 2012 | 05:33 PM
sponge14's Avatar
manual boost controller
Old Mar 15, 2012 | 05:35 PM
Garret's Avatar
Manual boost controller.
Dude, you should have just made one thread, I'm totally up to date on the progress of your car and I only had to read thread titles
Old Mar 15, 2012 | 05:44 PM
Dart_SI's Avatar
Lol. I know. I get info hungry and searching has yielded poor results.
Old Mar 15, 2012 | 07:16 PM
vahdyx's Avatar
I thought manual boost controllers were bad...
Hmmm.... maybe I should consider one
Old Mar 15, 2012 | 07:38 PM
vahdyx's Avatar
What MBC did you use?
I found a TurboXS one, is that any good?
Old Mar 15, 2012 | 08:02 PM
brant's Avatar
i got the one from dejon
Old Mar 15, 2012 | 08:03 PM
Ch1ck3n's Avatar
Right, but the turbine side is still the stock housing. While the bigger compressor will still make more power, it is limited by the small exhaust side.
An mbc would definitely make a much smoother boost curve but it would still fall off a little bit up top just due to backpressure.
Maybe I'm misinformed, but this has always been my understanding of turbos.
