BNR losing boost top end
Old Mar 15, 2012 | 10:21 PM
Area47's Avatar
Rent me! per hour
Originally Posted by CCrunner84
What'd the tuner have to say about the noise? That didn't sound right, could be the wastegate like you had mentioned, may attribute to the noise you've been hearing too.
it's fine. this isn't my first turbo car i have ever tuned.
Old Mar 15, 2012 | 10:41 PM
Dart_SI's Avatar
alright, so i did a boost leak check. the BOV was leaking pretty good where it mounts (not the bov itself).
havent drove the car yet, i used some gasket maker and its holding now tho, once it cures in an hour ill go for a drive and see if it helps at all.
if not then ill try putting more preload on the wga
if that doesnt work, im getting an MBC
if THAT doesnt work.... well **** idk what to do after that. lol. but i think itl be better now.
Old Mar 15, 2012 | 11:02 PM
MS3 2 SSTC's Avatar
hope it works out for ya! in for results for the results on the gasket matter
Old Mar 15, 2012 | 11:03 PM
Dart_SI's Avatar
well on top of the gasket maker, i added a new o-ring. bitch does not leak now. lol.
Old Mar 15, 2012 | 11:05 PM
FasterIsBetter's Avatar
Yeah, I hope it works for you. I figured you had a significant boost leak somewhere.
Old Mar 15, 2012 | 11:12 PM
Chevycobaltss3's Avatar
Well the main thing is the turbo is still small ( It should hold better then that).. The boost leak may be helping the falling out... the thing about the bnr is the wastegate itself is a lower pressure wastegate so the pid has to work hard to keep a good amount of boost. So a mbc is recommended... I had team ss tapering down to 22lbs from 24lbs back when i first tuned him because the 22 is the most i could get on the top end. And i told him he needs a mbc.. Now i have him tuned still running the mbc inline with the pid controller and it hold perfect..!!!!!!!! Even though i only have him at 24lbs, im sure if i went to say 28 he would prob taper down a lil!!!
Old Mar 15, 2012 | 11:14 PM
Dart_SI's Avatar
sounds like the same issue im having. yea, will be ordering an MBC tomarrow
Old Mar 15, 2012 | 11:39 PM
vahdyx's Avatar
Originally Posted by Ch1ck3n
Right, but the turbine side is still the stock housing. While the bigger compressor will still make more power, it is limited by the small exhaust side.
An mbc would definitely make a much smoother boost curve but it would still fall off a little bit up top just due to backpressure.
Maybe I'm misinformed, but this has always been my understanding of turbos.
Yeah this was my problem since Vince put so much boost on my tune, since I went HPT, the problem has been minimized a lot. With a ramp of boost instead of all at once
Old Mar 16, 2012 | 08:34 AM
Dart_SI's Avatar
Fixed a small boost leak, still having the same issue.
Tightening the wga today tonight to see if that helps while I wait for an mbc
Old Mar 16, 2012 | 10:14 AM
Chase0224's Avatar
you dont need a MBC to run 26. I run 26 all the way through and it only tapers to 25. No MBC here.
Old Mar 16, 2012 | 10:16 AM
  #36
turbo_chevy_cobalt's Avatar
When I had the Bnr on I was at 26psi and never had it drop any psi to redline. I didn't use a mbc.
Old Mar 16, 2012 | 10:33 AM
  #37
Dart_SI's Avatar
How much preload should be put on the wga? Its a 15 psi spring and it only has like 1 1/2- 2 turns of preload.
This issue is so annoying because it pulls like a monster till 5200 rpm or so when I start losing boost to 20.
I also don't get full spool till like 3700 rpm or later.
Old Mar 16, 2012 | 10:55 AM
  #38
donkeyballs's Avatar
didn't you say that you ran your valve cover line to the wastegate line or something? Try switching that just to see if it does anything.
Old Mar 16, 2012 | 11:08 AM
  #39
Dart_SI's Avatar
The breather line from the stock Turbo? I have it routed to my intake so no unmetered air gets in.
  #40
cubaniche's Avatar
Hmmm....yeah mine holds 25psi no prob. I made sure that the WG door was closed and then I gave it maybe two more turns. I know vince had to play with the WG table a bit to get it right since it was bleeding off too much at WOT. Mine holds 25psi to 7k.
Old Mar 16, 2012 | 11:09 AM
  #41
cubaniche's Avatar
Nice, howd you T that in or something? Were talking about the breather off the VC that used to go to the stock turbo right?
Old Mar 16, 2012 | 11:44 AM
  #42
Dart_SI's Avatar
Best way to describe my problem. Boost is bleeding past 5300.
My recirc tube for my bov is silicone so I just cut a small hole and tapped it in there. It was simple.
Old Mar 16, 2012 | 11:47 AM
  #43
cubaniche's Avatar
Nice. Dangit, I need to do the recirc already! Any other updates on your issue?
Old Mar 16, 2012 | 11:54 AM
  #44
Dart_SI's Avatar
Not really. Im going to try tightening my wga rod down more tonight after work and see if it helps. Fixing the boost leak made gains on the butt dyno but the bleeding boost issue still exists.
Old Mar 16, 2012 | 03:15 PM
  #45
Dart_SI's Avatar
update:
tightened the wga rod one turn, helped a little but it still goes from 26psi to 20 by redline. cant figure this out.
i need to get ahold of an MBC asap.
Old Mar 16, 2012 | 03:30 PM
  #46
Positive you have no more boost leaks? Full spool @3700rpms seems a little late for that turbo, but don't have any first hand experience with it.
Old Mar 16, 2012 | 10:44 PM
  #47
Area47's Avatar
Rent me! per hour
fix the boost leaks. bring the car back to me.
the leak is a huge issue. if you need it welded, we can head down to mkc and get that done. any leak after the maf just narfed the tune.
p.s. we're not going to be sideways at 70 mph while airborne again either
Old Mar 16, 2012 | 11:34 PM
  #48
Dart call me tomorrow ill tell you what to do with the rod.... I have fumble running 25 no mbc used.
Old Mar 16, 2012 | 11:40 PM
  #49
HHRSSouth's Avatar
I ran 26-27 psi on my BNR2871 to redline of 7k rpms, no mbc either. Full boost roughly around 3.3k rpms if I remember correctly.
Old Mar 16, 2012 | 11:49 PM
  #50
Yea the wategate rod needs adjustment... I did it and I can hold 25lbs by commanding no more then 72% wgdc and dals and ect
