Bogging/Will not NLS
Old Oct 10, 2011 | 11:12 PM
LiteraCola's Avatar
Hey guys. I've had my 09 sstc for a little over a year now. And I haven't had any issues with it until recently. Both unrelated I feel. First, occasionally when downshifting to pass a car, as soon as I ease down on the go pedal, the car bogs and sputters, losing all power. It almost caused my death on two separate occasions.
Second, I was never too confident about the 1-2 NLS, but I have since mastered it. So much fun, BUT, recently, when I try to NLS 1-2, I get locked out of 2nd. It's not that I can't do it, it just won't let me! It cost me a race against a rather enthusiastic portly couple in a new v6 charger. Haha. Can anyone point me in the right direction? Thanks guys.
Old Oct 11, 2011 | 02:26 PM
Boosted4's Avatar
How many miles do you have on you car? Do you have any mods done to the car? The sputtering or bogging could be a few things. The shifting is just basic clutch, pedal, and shifter operation. Check those to make sure everything is functioning as it should during a normal shift.
Old Oct 12, 2011 | 08:00 AM
LiteraCola's Avatar
There are just over 45k miles on the car. No mods other than muffler delete. As far as normal driving, I get the typical clunk when shifting (I miss my quietly shifting Hondas) but no real issues as far as drivability.
Old Oct 12, 2011 | 08:15 AM
BartSS's Avatar
Is your car always warmed up? Also check your plugs and or it could be a coil going bad. I had one of mine go bad at like 30K man
Old Oct 12, 2011 | 04:36 PM
asanti's Avatar
I agree w/ Bart, take a look at the plugs and change them just for piece of mind. My plugs started to cause misfires at 36K; i've had no problems w/ misfires since installing new plugs in there (*knock on wood).
Later
Allex
Old Oct 12, 2011 | 04:47 PM
DerekDTP!'s Avatar
plugs do beautiful things for our cars lol
Old Oct 13, 2011 | 06:49 AM
LiteraCola's Avatar
I never beat on the car unless it's totally warmed up. I learned my lesson with my first car, a VTEC
Old Oct 13, 2011 | 08:13 AM
BartSS's Avatar
haha that Vtec dont really work when cold
Old Oct 13, 2011 | 08:30 AM
LiteraCola's Avatar
Sorry. Stupid mobile site. There was more to that message, although I can't remember, other than the fact that I learned my lesson with my old Prelude, trying to show off with a cold motor. VTEC no likie being cold haha.
Its not fun to pull out to pass someone in a hurry and then all of a sudden have no go juice.
Old Nov 7, 2011 | 02:29 PM
LiteraCola's Avatar
Bump... The car still won't NLS from 1-2... .
Old Nov 7, 2011 | 05:17 PM
asanti's Avatar
Time for a dealer visit then? Have you ever tried to adjust the cables? I'm an auto guy here but aren't the shifter cables adjustable in the Cobalts? It might be worth a look.
Later
Allex
Old Nov 7, 2011 | 05:28 PM
2010SS's Avatar
Roll pin is stretched which will cause u getting locked out of a quick 1-2 change the roll pin and it will work again, however most people don't recommend nls 1-2
Old Nov 7, 2011 | 05:30 PM
Martel18SS's Avatar
Try to NLS earlier. Like 5700-5800 rpm. If that doesn't work, try at 5500-5600. If that still doesn't work then something is dearly wrong.
Old Nov 7, 2011 | 05:50 PM
Frogstofall's Avatar
Where is the roll pin?
Old Nov 7, 2011 | 09:05 PM
FasterIsBetter's Avatar
Your roll pin is on your shifter lever on the transmission. Search is your friend. Look up the how to on replacing the roll pin.
Old Nov 8, 2011 | 01:14 PM
FRQ FLYR's Avatar
I would echo these tips on the shifter; had the same problem and shifting at lower rpm helped. After my linkage broke shifter was replaced and problem hasn't resurfaced.
Regarding the engine- you've established you don't beat on it when cold and you haven't mentioned any cel's/codes so the first thing I would try is a little seafoam thru the vaccum port on the intake manifold. It's been documented that our intake valves gum up quickly which may lead to hesitation/misfires,etc. It's easy and cheap as are plugs which would be second on my list.
007Buff
Jun 11, 2017 03:04 PM
Hugger1975
Oct 15, 2015 03:28 PM
007Buff
Sep 22, 2015 09:48 AM
The Rookie24
Sep 20, 2015 04:33 PM
The Rookie24
Aug 27, 2015 09:18 PM
