boost gauge readings
Old Dec 20, 2013 | 04:41 AM
tuned08ss's Avatar
So at idle my vac is at -18, which I find normal. But when driving and I let off the pedal it drops to -22 inHG. This is only sometimes. Is this normal because I thought it should be at -20. Vacuum leak maybe?
Old Dec 20, 2013 | 04:49 AM
If you had a vacuum leak you wouldnt have more vacuum. Unless you were trying to say it the other way around
Old Dec 20, 2013 | 04:52 AM
GreenySC2's Avatar
When I'm sitting at idle be it parked or at a light mine always reads -20....
Then again I am using the stock gauge no rpd yet
Old Dec 20, 2013 | 07:25 AM
blueLNFftw's Avatar
-18 at idle is good.
it will always drop lower when in the higher RPMS and you close the throttle.
Since vaccum is read in the negative, if you had a leak it would be a higher value (aka closer to 0)
Old Dec 20, 2013 | 08:15 AM
tomj77's Avatar
Ya when u let off the gas it would fall to -20 somewhere, ur engine goes from being in a close to boost state to going into a more vacuum state when u release the gas. It's normal.
Old Dec 20, 2013 | 08:17 AM
tuned08ss's Avatar
Ok thanks guys. Btw I just got a p013e code. Wtf
Old Dec 20, 2013 | 08:28 AM
blueLNFftw's Avatar
Forget that code.
Tune it off.
Old Dec 20, 2013 | 08:40 AM
tuned08ss's Avatar
Forget that code.
Tune it off.
Im about to buy hp tuners. Which one do I buy? Suite or pro? I am tuned already but done by the previous owner. Its not trifecta because I already contacted Vince. Just ready to mod more and get a fresh tune.
Old Dec 20, 2013 | 08:42 AM
blueLNFftw's Avatar
LNF have a wideband built in so you would only need the standard. You can get it from ZZP for 499 shipped. That is like the going price everywhere so mays well buy from a cobalt supporter.
Old Dec 20, 2013 | 08:45 AM
tuned08ss's Avatar
Ok and I'm in NJ but I want a remote tune. Anybody you recommend in my area?
Old Dec 20, 2013 | 09:04 AM
Staged07SS's Avatar
Administrator
Administrator
Read this:
Tips on Reading Gauges: Vacuum Gauges
Old Dec 20, 2013 | 09:16 AM
yellowsupercharged06's Avatar
for an LSJ this is normal, not sure about an LNF
Old Dec 20, 2013 | 09:20 AM
Sox-Fan's Avatar
Got Brakes?
If you want a remote tune why does it matter if they are in your area?
Old Dec 20, 2013 | 09:23 AM
he is a newb, im not too sure he really understands the entire process.
but since your in NJ Tuned08, wait til spring when the weather is warmer.
Old Dec 20, 2013 | 09:25 AM
tuned08ss's Avatar
I understand the process but at the same time would still like it to be kind of local
Old Dec 20, 2013 | 09:29 AM
there is a guy up in CT that I know of.
Old Dec 20, 2013 | 11:04 AM
tuned08ss's Avatar
09cobaltss1?
Old Dec 20, 2013 | 11:05 AM
09cobaltss1?
thats who i usually suggest... im in LI and have HPT if you need to use it .... its closer than driving up to CT
Old Dec 20, 2013 | 11:40 PM
tuned08ss's Avatar
Thanks I will keep that in mind but wouldn't it be better for me to buy my own if I plan on continuous mods and tune updates?
Old Dec 23, 2013 | 12:55 PM
Sox-Fan's Avatar
Got Brakes?
why do that if you're only going to consider a local tuner?
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
