Boost leak
Old Mar 7, 2011 | 06:37 PM
xodus's Avatar
Boost leak
I cant seem to find the boost leak and i cant get it on our lift right now to look from under neath, what happened was i came out of first gear to like 4500 pushed in the clutch and you heard a psh just like when the charge piping popped off. Took it home checked all connections, and clamps, there fine and tight, i looked at the bottom of the end tanks in the intercooler and there fine, i can drive normal, but once you go into boost you get a loud hiss of the leaking coming out, but idling its completely normal, any suggestions until i can get it on the lift?
Old Mar 7, 2011 | 08:44 PM
jarhead's Avatar
Check the hose going into the bottom of the intake manifold That one is a pain to get on and hard to get at not a lot of room you will most likely need a flashlight to see it well. That clamp is a worm gear drive and I have seen them fail.
Old Mar 7, 2011 | 09:11 PM
SSlobalt's Avatar
You popped the coldside IC endtank. Feel between the bumper and the face of coldside endtank. You should feel a hole or a crack.
Old Mar 7, 2011 | 09:17 PM
Red_SS/TC's Avatar
Yeah you should take off your bumper. Im pretty sure you cracked your ic somewhere on the plastic endtanks.
Old Mar 9, 2011 | 11:54 AM
jarhead's Avatar
So what was it? hope wasn't you're intercooler end tanks.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
