Boost Leak?
Old Nov 2, 2011 | 05:47 PM
vahdyx's Avatar
Boost Leak?
So I got my stock turbo put back on and I'm curious is this noise normal. It's a very faint whistling noise. It's louder in my car, but still faint. Most passengers don't even hear it. The noise dies off when I get in higher RPMs and if I shift from 2nd to third it's not there. But if I WOT in third or fourth the noise exists. I haven't noticed it with WOTs in first or second
Cobalt SS Turbocharged Turbo Death Whine? Part 1 - YouTube
Cobalt SS Turbocharged Turbo Death? Part 2 - YouTube
Vince thinks it's normal, but he can't hear it.
My LTFT's made it to -2.3 once, but usually around -0.7 or -1.5
My boost as you can tell in the video hits the right amount and stays there, my car pulls as hard as it's always had, I can't feel a difference.
A friend of mine thinks it's normal with a GTI thinks it's normal. His GTI makes a noise too and has since he's owned it. He bought it new and it has 80k miles on it.
Thanks for your opinions.
Old Nov 2, 2011 | 05:54 PM
Superbalt06's Avatar
Make a boost leak tester and test the system. That's the best way to find a leak. Spray soapy water on all places air could leak while it's pressurized. If the system holds pressure there's no leak.
Old Nov 2, 2011 | 06:02 PM
SSlobalt's Avatar
What kind of intake?
Old Nov 2, 2011 | 06:04 PM
vahdyx's Avatar
Its in my sig, but a ZZP intake tube and ZZP's Airbox Mod
Old Nov 2, 2011 | 06:07 PM
SSlobalt's Avatar
You can boost leak test it to be sure, but if you can hear a boost leak, that means it's so big that you wouldn't be building that must boost. This leads me to believe it's somewhere on the intake side, or you have a fading turbo.
Old Nov 2, 2011 | 10:55 PM
vahdyx's Avatar
It only happens when I get to 15psi so would that indicate a leak since the pressure is to high or can't really tell. How do I check the intake, just take off everything and check?
I also have a MPx catch can could that leak and create the whistling noise
Old Nov 3, 2011 | 12:39 AM
FasterIsBetter's Avatar
I have the same noise. Pretty sure its the turbo tho. I've went over boost leaks about 6 times on my car in the past month. Found two but they were making really loud noises. All I have to say is "OH WELL!" cause its getting built soon with a 6758 added to it.
Old Nov 3, 2011 | 07:37 AM
vahdyx's Avatar
How long has it been doing it? And you're pretty sure its the Turbo as in dying?
Old Nov 3, 2011 | 10:13 AM
A good way to tell is pull off your intake and check for shaft play on the compressor wheel. Try to wiggle it. If it wiggles its bad.
Old Nov 3, 2011 | 04:57 PM
asanti's Avatar
Wait, don't all turbos have SOME shaft play? Not being a dick, just looking for info.
Later
Allex
Old Nov 3, 2011 | 05:15 PM
snoftall's Avatar
My car makes a similar/the same noise when under full boost. Never made it when it was stock, but then started to make it after I had GMS1 installed. I assumed it was due to the higher boost pressures. Same thing you said though, no one else seemed to notice it until I pointed it out.
Old Nov 3, 2011 | 05:16 PM
SSlobalt's Avatar
If it runs fine, I would just not worry about it.
Old Nov 3, 2011 | 05:29 PM
Later
Allex
Yea, the bearings are going to have tolerances but if theres excess play he should notice it. If he wiggles it and the compressor wheel goes clonk clonk then the bearings are shot. Maybe I should have put clonk clonk in there....lol
Old Nov 3, 2011 | 06:50 PM
SSlobalt's Avatar
"Clonk, clonk" is a purely scentific term. True story.
Old Nov 7, 2011 | 05:00 PM
vahdyx's Avatar
Haven't had time to check the "Clonk Clonk" yet, but BYT thinks since we reused the gaskets when putting back on my stock turbo (since they were only a week old), that that's what's causing the whistle.He thinks by the sound it's probably the manifold gasket.
Any opinions on this?
Old Nov 7, 2011 | 09:01 PM
Idk man. Mine does it and my turbo has never been off afaik, I can ask RossGo(original owner) if he ever had it off but I have that same exact high pitched whine.
Old Nov 7, 2011 | 11:12 PM
vahdyx's Avatar
I spoke with a GM tech and he thinks a high pitched whistle is a vacuum leak. He thinks I have either a pin hole somewhere or chargepipe or intake or something isn't tight. May need to be reworked or my intake or silicone ends need to be replaced.
Depending on the chemical the shop used to clean all the oil out, there could be some deterioration.
There could be a lot of things.
Oh and I felt the shaft and it didn't wiggle. It was nice and solid...
Old Nov 7, 2011 | 11:49 PM
Yea, just go over it I guess, man. I went over my stuff a bunch of times and found nothing other than a stuck purge valve solenoid. Ordered a new one over the weekend. If I find something else I'll inform ya but unless its my intake manifold leaking where the original owner had pulled it previously to shave and paint it and reused the gasket I don't know what it is because I have went over my stuff time and time again even pulled the bumper off. Just get you a boost leak tester or build you one. I'm building one this weekend so I don't have to wait for it to come in.
Old Nov 8, 2011 | 03:45 PM
RyRidesMotox's Avatar
Check all of your connections first. It may be in the intake, before the turbo so don't forget to check there... negative pressure is still pressure.
Old Nov 8, 2011 | 09:37 PM
Sonicyeller's Avatar
My car makes the same noise even since I bought it. I'm pretty sure that's just how these K04s sound at high boost levels. Skip to about 2:25 in the video below.
Cobalt SS/TC Sedan Compilation - YouTube
And I'd think you'd agree that my car runs correctly because its right on par with where I should be at Bandimere with the mods I have.
Old Nov 8, 2011 | 09:50 PM
vahdyx's Avatar
yeah I hear it, you crazy NLSer! Very nice video by the way
Old Nov 8, 2011 | 09:59 PM
LOL Thanks. I've gotten much better at NLS'ing the **** out of may car since that video too. Go watch some of the videos where I race a full bolt-on and cammed LS1 Camaro on my channel if you haven't already. BTW, I wish my car held 25psi to the upper RPMs. My GMS1 hits about 23psi and then tapers off to almost 17 or so by 6000rpm.
Old Nov 11, 2011 | 06:39 AM
FrossB's Avatar
Thread Killer
not that i think that this is what it is but, my turbo made a whistle/humming noise like that when i had a messed up blade internally. you wouldn't hear anything until a little past 10psi then it would whistle like a bird.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
