Boost leak test
Old Apr 12, 2010 | 08:58 PM
cmiller8006's Avatar
Boost leak test
I know it was on here not to long ago but couldnt find it. I am just going to do a test before the track. How much should you pressurize the system?
Old Apr 12, 2010 | 09:01 PM
madmark's Avatar
15-20psi
Old Apr 12, 2010 | 09:38 PM
peachpuff's Avatar
I aim for 25psi.
Old Apr 12, 2010 | 10:20 PM
ok, thanks guys.
Old Apr 12, 2010 | 10:22 PM
DoMiStIc_RuSh_06's Avatar
How do you do a boost leak test.
Old Apr 12, 2010 | 10:28 PM
I got a tester for 20.00 from the boostpro wedsite. It attaches to the intake of the turbo and you hook it to the air compressor and pressurize and you will here the leaks.
Old Apr 13, 2010 | 01:31 PM
Terminator2's Avatar
A little soapy water solution around all the connections will help spot small leaks.
Old Apr 14, 2010 | 05:29 PM
OK, I found out that if you have just a breather on the line that had the pcv valve, you already have a boost leak the size of Texas. I am going to try and get a new intake tube and pcv valve from the shop under warranty.
Old Apr 14, 2010 | 06:14 PM
SSlobalt's Avatar
That just means you didn't cap off the coldside tube at the throttle body. The pressure you're applying through the compressor is going past the TB into the crankcase and pressurizing it. You should remove your oil cap if you're going to do it that way. Our intake tube are impossible to reach, so I guess I understand why you're doing it that way.
Old Apr 14, 2010 | 06:38 PM
I believe he's talking about the line that goes from the valve cover to the intake tube.
Old Apr 14, 2010 | 06:54 PM
I was told to take off the airbox and do it threw the intake tube. Wasnt told you had to take it off the throttle body or anything but maybe I will try and do it that way.
Old Apr 15, 2010 | 12:43 PM
SSlobalt's Avatar
Sorry to send you back to the hardware store, but it's the right way to do it. Someone always points out that you're not testing the TB connection, but that connection doesn't generally leak.
Old Apr 15, 2010 | 01:04 PM
Matt M's Avatar
Are you guys plugging both of the PCV tubes before you pressurize the system prior to the turbo? If not, then you are going to pressurise the crankcase.
You also have to be careful with how much pressure you put through the turbo and how long you leave it connected. The turbo will be spinning without any fresh oil being pumped through it. I prefer to cap off the turbo inlet and then pressurize the system beyond the turbo.
tom.g's Avatar
Which one? http://www.boostpro.net/prodtester.html
I want to check to see if I have any boost leaks with the Injen CP's.
Old Apr 15, 2010 | 03:12 PM
Yep, got the universal one. I think there both the same tho.
Yea I found that if you try and put pressure in through the intake, it blows air right through the oil fitting that goes to the valve cover. I took off the oil cap like it said to do. But I think I need to get a pcv valve on the car lol.
Last edited by cmiller8006; Apr 15, 2010 at 03:12 PM. Reason: Automerged Doublepost
Old Apr 15, 2010 | 04:49 PM
SSlobalt's Avatar
That's whay I was saying. I pull the coldside at the throttlebody and cap it before doing the test. It's a real pain, I know.
Thanks for the tip on the turbo. I usually find the leaks pretty quick, but it's good info.
Old Apr 15, 2010 | 05:45 PM
Matt M's Avatar
Capping off the charge tube at the TB doesn't keep you from boosting the crankcase if you still have the vent hose running from the turbo to the valve cover.
Old Apr 16, 2010 | 12:17 PM
SSlobalt's Avatar
Cool. Thanks!
Old Apr 16, 2010 | 11:16 PM
tom.g's Avatar
So the 3" DSM one will work?
Old Apr 17, 2010 | 04:26 PM
http://www.modernperformance.com/inc...es-p-1971.html
will this work? So I would need to put this on the intake side of the turbo and pressurize the system?
Old Apr 17, 2010 | 04:43 PM
SSlobalt's Avatar
Here is my tester that I built for around 10 bucks. All parts were from Home Depot.
I was attaching it to the input port of the turbo where the intake tube goes on, removing my oil filler cap from the valve cover, pressurizing it to 20 psi, and checking for leaks. I also blocked the coldside tube at the throttle body with a plug, but that was a pain in the ass. ZZP says we're still getting positive pressure to the valve cover through this line:
I don't know how to bypass. You'll just have to put up with the deep air noise coming from the oil filler cap hole, I guess.
Old Apr 17, 2010 | 04:49 PM
I would say that the best way to do it is to take the charge pipe off the turbo and start there, cap off the cold side at the throttle body and put a vacuum cap over the line where the hose goes from the lower cp to the boost solenoid.
Old Apr 17, 2010 | 04:52 PM
SSlobalt's Avatar
I'd say that's probably right, but I don't know about the boost solenoid thing. I think the pressure just stops at the solenoid.
Old Apr 17, 2010 | 05:02 PM
How do you know how much pressure your putting into the pipes, if you just using a regular compressor
Old Apr 17, 2010 | 10:29 PM
SSlobalt's Avatar
Sorry I didn't answer earlier. There was another database error, so I gave up. Anyway, I control the pressure with the regulator on my compressor.
