Boost pressure
Boost pressure
Idk if this is normal or somethings wrong. I have an intake and im tuned with the Bsr Ppc. When im at WOT I hit about 23-24 psi and as the rpms are going higher the boost slowly drops down to 20 psi. Im just wondering if thats normal or I have a boost leak or something.
I like the power I got from the tune and im stuck on what I should get next. Im either going to get Hahn exhaust, Hahns catless dp, or hahns charge piping. What do you think I should go with.
One more question with the catless dp, in Texas if I dont have a cat but im also not throwin any codes will I pass emissions?
Thanks
Thanks
The boost "issue" you're having is actually normal. Nearly all tunes will do something similar too.
If I was you, I'd leave the exhaust alone from a performance standpoint. I'd look into the downpipe and charge piping though. Downpipe is a big performance and sound mod in one. The charge piping is a slight performance mod, but is more of a just-say-no-to-plastic mod so you don't have any issues with the increased boost.
You shouldn't have any issue with a clogged cat or anything unless you're running super rich (like in a bad way).
And the sound.. oh it's wonderful. You hear all the pop, whistles, gurgles, etc. The sound will deepen and mellow a bit too as you put miles on it and break it in.
I think like November of 2010 or something like that so idk ill just keep my stock dp. but now im just looking into the catted. wow i hate deciding what to get for my car haha
If you decide to go catless, just remember to slap the stocker on a few days ahead of time so that the emissions system says "READY". You'll have less chance of a fail that way.
With counties that don't have the sniffer inspection, it just depends on the inspector. If the inspector actually looks for the cat and doesn't see it, you'll fail. Most don't look, though.
I would just go with the catted DP. The catless seems like it's too loud, anyway.
Didnt feel like reading all that but you will notice boost drop because of stock restrictions in the turbo system on the intake sides and the exhuast sides and our lil turbos have a hard time maintaining boost in high RPMs. and you will see boost spikes on inicial boost build and between shifts and will drop off some.
A muffle delete is where you cut ur muffler off and put in a piece of pipe or nothing
Sl0wbaltSS
Nov 21, 2018 11:11 PM
