Boost problems
Old Jul 3, 2012 | 08:51 PM
20BLACKBIRD02's Avatar
Boost problems
Well I went to pick up food and my car started running weird and just died ad won't build boost, now it runs fine just no boost, all charge piping and fuel pump are working just dunno what could be causing that!
Old Jul 3, 2012 | 08:55 PM
brycerice13's Avatar
most likely a boost leak or a bad sensor.
And no check engine lights
Which sensor?
Last edited by 20BLACKBIRD02; Jul 3, 2012 at 08:55 PM. Reason: Automerged Doublepost
Old Jul 4, 2012 | 01:40 PM
Jumpship's Avatar
Do you have the stock intercooler?
Old Jul 4, 2012 | 01:41 PM
Yeah I do
Old Jul 4, 2012 | 01:47 PM
It could be the map sensor, or your could have a boost leak anywhere, so what is happening the MAF is reading so much air coming in and its not matching up with the MAP sensor so it is making it run weird. Check for boost leaks first. If you don't find anything then I would start to try to trouble shoot if the MAP sensor is going bad.
Old Jul 4, 2012 | 01:58 PM
dayhoff35's Avatar
sounds like a leak or bad sensors, weird it doesnt have a code if it was a sensor though, make sure all charge pipe couplers are still on.
Old Jul 4, 2012 | 02:12 PM
I took all the pipes lose and put em back together, I think it helped. I'll now when the car is cold and it sounds like a jet taking off lol
Old Jul 4, 2012 | 03:29 PM
SSlobalt's Avatar
That's the catalytic converter warm-up mode.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
