Boost spike problems
Old Jan 29, 2012 | 08:58 AM
chipsgt's Avatar
Thanks everyone for your help. There is a lot to go over here. I am going to have to do some research before I start yanking things off the car and cleaning them. I just dont know where everything is yet. I DID attempt to take the valve off yeserday, but I couldnt get a wratchet in to loosen the back bolt on the valve. So I just buttoned it back up and decided to wait.
Vince is looking at my data logs and is going to let me know what he finds.
Thanks again guys.
Old Feb 18, 2012 | 10:01 AM
chipsgt's Avatar
Okay, maybe I am partially retarded, but I can not figure out how to change this damn BPV. Its tight in there, but I think I can deal with the farther two bolts. I have having a **** load of trouble with the one closest to the front of the car. I can get a 10mm socket on it, but the space is to tight to get a wratchet on there. There is a metal line and bracket blocking me, and the space is too small to get a wrench on it. So, and suggestions? I know this is supposed to be easy, but I am just dumb.
Old Feb 18, 2012 | 10:17 AM
user 70823082's Avatar
It's a pain but try going from the back (in before that's what she said)
Old Feb 18, 2012 | 11:29 AM
Frogstofall's Avatar
That's what she said....
You have any swivels? What about one of the mini ratchets?
Old Feb 18, 2012 | 12:56 PM
raver0789's Avatar
What do you mean when there is a gunfire noise when the boost spikes?
What causes such a gunfire noise?
Old Feb 18, 2012 | 02:02 PM
chipsgt's Avatar
What do you mean go in from the back? I only ask because there seems to be only one way to get at it. If I stand on the passenger side of the car, and lean in behind the intake tube, I can see two bolts and feel the back one I am pretty sure I can use a 10 mm open ended to slowly get the back bolt, but just have nothing that will get that front one. The open ended wont turn it. Just due to lack of space.
Yu recommend a mini ratchet?
I can try one of those, but I will need to buy one. Is there a how to on here that you guys know about? I tried searching for one, but came up with nothing.
Old Feb 18, 2012 | 02:07 PM
Take your intake off.
Old Feb 24, 2012 | 07:24 AM
chipsgt's Avatar
I was trying to avoid that. Just do to the limited amount of time I have had lately.
I caught a break yesterday though and was able to have not only an hour of good daylight to work with, but it was 65 degrees out. I am actually glad I took the intake off, because as it turns out it wasnt completely tightened up. It always had the slightest amount of play in it.
But, I took out the Forge valve, which, the hole was facing the front of the car, not down. Could that have been causing my over boost problems?
I put in the stocker, got everything fastened up and presto! Absolutely no more overboosting. I turned on the Trifecta tune, and was able to keep it floored without worry.
Oh, and holy effing rocket batman.
So either the Forge valve that came on the car was defective, or the hole being sideways was the issue. Either way, its better now. I am going to leave it stock for the time being so I can get back in the Generals good graces. Thanks for everyones help on this! Escpecially RKRamos for the hook up on the stock valve.
Dude offered me the part at a reasonable price, and had it shipped same day. Thanks man!
Old Feb 24, 2012 | 02:04 PM
Stamina's Avatar
It shouldn't. In theory, your wastegate is wholly responsible for boost control, and the BPV/BOV has nothing to do with it.
If the BPV/BOV were not installed correctly, you would probably have weird issues when letting off the throttle a bit when cruising, or when letting off after getting on it. You would've had some turbo flutter happening, turbo response would suck in between shifts, and the car would probably buck sometimes.
Maybe a person more knowledgable can chime in here. Perhaps the LNF uses the BPV to help supplement boost control in addition to the wastegate in this case.
Old Feb 24, 2012 | 03:39 PM
SSlobalt's Avatar
Good to hear you have it running, chip! Just leave the stock BPV in. The Forge is a waste of money. It's pretty and all, but it requires maintenance.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
