bpv spring
Old Mar 3, 2009 | 01:06 PM
blackrocky's Avatar
bpv spring
i just got the dejon bpv spring in the mail and now im havin doubts about installing it. give me some good reasons to put it in
Old Mar 3, 2009 | 01:08 PM
Black08SSTC's Avatar
when u get an intake its almost as loud as a BOV. Plus its about a 10 min install and GM probably would never know
Old Mar 3, 2009 | 01:09 PM
blackrocky's Avatar
well since i dont have an intake i wont install it
Old Mar 3, 2009 | 01:10 PM
Terminator2's Avatar
It seals better than the stocker and it closes a little faster after you lift to shift that decreases spool time some. It sounds better if you have an aftermarket intake, and even as the spring sags and looses tension over time it will still have more holding force than the stock spring when new. There you go
Old Mar 3, 2009 | 01:12 PM
2FST4U's Avatar
I am ordering mine this week
Yea, the new spring is hard as hell compared to the soft GM one
Old Mar 3, 2009 | 01:15 PM
turbo08ss's Avatar
where can i order his spring
Old Mar 3, 2009 | 01:16 PM
Search dejon powerhouse in google.
Old Mar 3, 2009 | 01:21 PM
blackrocky's Avatar
lol!
Old Mar 3, 2009 | 02:31 PM
SSpdDmon's Avatar
Personally, I would like to hear a better technical explanation of how this part works (the BPV and stock spring). When I look at the pics of a disassembled one in the other 10+page thread, it looks like the spring is overcome by engine vacuum when you want the turbo's excess airflow to bypass entering the engine...and that boost pressure PLUS the spring pressure closes the valve when you don't. So on one hand you may be assisting the valve in sealing off the path of boost with extra spring pressure, but it seems the engine vacuum has to overcome that extra spring pressure to allow boost to bypass entering then engine. Therefore, I don't know if it's a true fix if your having minor boost leak issues.
Can someone (preferably someone who knows for sure) elaborate a little more on how this part functions.
Old Mar 3, 2009 | 02:39 PM
Originally Posted by SSpdDmon
Personally, I would like to hear a better technical explanation of how this part works (the BPV and stock spring). When I look at the pics of a disassembled one in the other 10+page thread, it looks like the spring is overcome by engine vacuum when you want the excess airflow to bypass entering the engine...and that boost pressure PLUS the spring pressure closes the valve. So on one hand you may be assisting the valve in sealing off the path of boost with extra spring pressure, the engine vacuum has to overcome that extra spring pressure to allow boost to bypass entering then engine. Therefore, I don't know if it's a true fix if your having minor boost leak issues.
The spring is attached to a plunger like diaphram that seals the BPV shut while the car is under boost. When you let off to shift the throttle closes and creates a vacuum in the little black line that connects to the BPV that pulls the valve open on the throttle is depressed again the vacuum no longer exists and the spring slams the BPV shut. When you let off the engine is at 20lbs vac the spring rate is 9 lbs/in. stock the aftermarket one is 13lbs/in. 20 lbs vac will open it all the way everytime.
Old Mar 3, 2009 | 02:43 PM
SSpdDmon's Avatar
Yes, the spring will help shut the valve when the engine is operating in little to no boost and no vacuum. But, the same way the hose opens the valve under vacuum - it closes the valve under boost as the hose becomes pressurized too. That's my point....
Old Mar 3, 2009 | 02:46 PM
Yep, but the stock spring get kinda weak over time and it looses its abiltty to close and seal as well. The New spring Definately helped reaction time of the turbo between shifts IMHO, and it sounds crisper when it releases.
Old Mar 3, 2009 | 03:01 PM
jwhitten's Avatar
My spring a a tad bit shorter then the stock also I guess to compensate for the extra tension of the sfter market spring. I dunno about anyone else but my car never spiked 24.5 psi until I installed this spring so it seems to me at least in my case it does its job and picked me up about 1.5psi I dunno what would have caused this but before the spring I was spiking 23 and droping off to 22 now I spike 24.5 and drop off to 22.5
Old Mar 4, 2009 | 09:40 PM
JsavageSS/TC's Avatar
How do I install this????
Old Mar 4, 2009 | 09:47 PM
SUKXOST's Avatar
I have it....but I do know that Bill Hahn says it's unnecessary.
Old Mar 4, 2009 | 09:58 PM
Lowering springs...........
For The TC
I know how people like to post their SC and NA stuff in a TC thread....
Can anyone post a pic of their lowered TC and tell me what springs they used?
I am thinking about going to with the Pro eibach's
well ****, this was supposed to be a new thread, damn internet
Old Mar 4, 2009 | 10:04 PM
batboy's Avatar
I remember seeing a thread with pics that covered how to install the spring. It looked really easy.
Old Mar 4, 2009 | 11:39 PM
Mazdaboi318's Avatar
so does it really make it louder? lol
Old Mar 4, 2009 | 11:40 PM
supermantxz24's Avatar
I didnt really see a difference either but hey it was $10
Old Mar 5, 2009 | 11:59 AM
L.P.'s Avatar
It does make it quite a bit louder and the BPV sounds like a BOV...spool time seems to be better as well.
Old Mar 5, 2009 | 12:01 PM
2FST4U's Avatar
yay for faster spool.
Old Mar 5, 2009 | 12:31 PM
I woulda never guessed that it would get louder. But i guess with an intake it might be too loud? Can people hear our stock one outside the car? i only hear it when my music is down
Old Mar 5, 2009 | 12:33 PM
widowedeight's Avatar
if you wanna know what you will sound like with an intake just take your filter out and drive around the block HUGE differance (just make sure to put the intake back in)
Old Mar 5, 2009 | 07:11 PM
People always asked if it was turbo'd......they say they thought thats what it sounded like
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Sep 27, 2015 08:53 PM
