Brake dusting
Brake dusting
I have a 2010 SS and the Brembos are brake dusting really bad is this a common problem? The dust is coating the entire inside of the rim making it completely black. Also who makes good brake pads cause my rears are already squealing loudly(only 15k on it now)
Yes that dust is normal. Not just a cobalt issue either, all brembos.
but I have no idea who makes good pads for squealing performance. I buy Hawk HP+ pads for braking performance and they squeal like a freight train.
I know HAWK HPS pads are a step down in braking performance and a step up in squeal resistance but I dont know how they fair relative to stock because I've never bought them.
Yes, the Brembo pads will do this. They would cover my wheels in a week. The HPS pads would take a month easy to get the same amount of dust.
For the rears, check the inside portion of the rotor. If it is groved or gouged, they are toast. On mine, the slider pins were not even lubed up. They were bone dry causing my problems.
I went with Hawk HPS pads front and rear, and R1 Concept rotors to match. They have been a great combo on this car.
i was told the brembos squeal because they are high performance breaks, they do it bad in the wet....just because they are high performance, thats coming from a bulliten on GM
You generally have a choice between awesome braking performance with pads that can actually handle some light track abuse or pads that don't dust and don't brake as well. GM went with the great pads and I've been extremely happy with the fronts despite the increased dust. The rears are also a very good pad but have an extremely short service life and tear up the rotors.
If you want less dust and don't track the car you should be able to find quite a few other street-biased performance compounds, especially for the rear as the calipers and pad fitment is shared with quite a few other cars. Others might be able to make some suggestions as to what they've tried. I've had good experience over the years with Performance Friction, Hawk, Porterfield, and EBC for performance pads and each company makes pads biased towards street or pads for track duty although options for the front Brembos may be limited with some of the companies.
In the mean time one other thing you can try that should help is next time you have the wheels off for a tire rotation, clean them really well and apply a few heavy coats of a good wax to the wheel surfaces. This can help with cleaning and getting the brake dust off. With how big the wheels are and the space between the spokes it's pretty easy for me to wash and clean the interior surface of the rim without taking them off the car so the dust doesn't bother me too much.
FROM EBC:
High Performance LOWEST DUST rating pads for Prestige imports and faster street driving.
There are TWO reasons our customers love Redstuff, First because they are the lowest dust pad we have encountered by reducing dust by 60-90%. Plus the minimal dust you see is very easily removed with a simple sponge wash as it contains no steel fibre particles as in ALL OTHER pads. Second they brake like an alligator right from cold (as good as Original pads or better) and just get better as they heat up.
This material is a KevlarŽ fibre based brake compound enhanced with ceramic particles. If you have previously tried EBC redstuff (pre-ceramic compound) this material is light years ahead. It lasts longer, it brakes better and is quieter.
Being a hard wearing pad, bed-in times can be as long as 1000 miles and drivers must be patient until the pad takes up the shape of their disc (brake rotor). This is a truly impressive fast road pad for repeated heavy braking.
It emits far less dust than semi-metallic pads and has been proven to stop a passenger car/sedan/sport compact/hot hatch 13 metres quicker than OEM pads from 100mph/160kph. Features EBC Brake-In surface coating which conditions rotor surface and accelerates pad bed-in. Nominal friction coefficient 0.5 with approx. 50% dust reduction.
My Hawk HP+ pads dont squeak at all on the track.
No squeak here either...front or rear. But the DUST is the *****. I'm going to try the EBC RED front and rear when I have to change em. Since I don't track the car, I'm willing to try these which should solve that problem. I think the Hawks dust more than the REDS. EBC REDS are combo ceramic/kevlar.
I'll probably just replace the pads with the stockers when they need to be redone. I don't care about the dust really. It's just a bye product of a disk brake system. If you don't like the black dust you can always go with ceramic pads that have a very light grey dust. I'm sure someone makes a ceramic in a racing compound, it would probably wear faster but it would stop just as good. Ceramic dissipates heat faster anyways and is more tolerant of heat as well. Look at the tiles on the space shuttle, ceramic, I rest my case. They are pretty expensive though.
big snip..
big snip..
Still Ferodo stock pads on the front Brembo's @ 52k miles.
Ron - I tried the EBC Reds on the rear for a month, threw them away, never quit sqealing no matter what. YMMV. Went with Hawk HPS, but the stockers bite better, I lost some high speed stopping power vs. the stock pads.
Ok..thanks. Interesting..I know they need bedding in...but I'm sure ya did that. Maybe on the rear, you don't have an opportunity to properly bed em in? I'm pretty sure the fronts won't be a problem...they should dust LESS than HPS too. I do want a lot LESS dust though, so maybe REDS up front and HP CERAMICS in the rear?
Not sure what I'll do next year, other than slotted rotors for the cold rainy days here but I do know I wish I had more stopping power at times.
I was thinking of HP+, but IDK. I don't care about the dust really, I detail it weekly when I have time anyway, wheels & all.
You guys think we have it bad with the brake dust... I wonder what the ZR1 guys brake dust situation is like. They have carbon metalic pads and ROTORS. They must have brake dust hitting them in the face through the A/C vents.
