Building boost in neutral
Old Oct 21, 2010 | 12:10 AM
sponge14's Avatar
I was just curious as to why our cars won't build any positive boost in neutral? Is it an ECM limiter, or is it something else that's preventing it?
I don't care that the car wont do it as I have no need to have that much power when I can already roast my tires in first without even thinking about it.
Old Oct 21, 2010 | 12:23 AM
tomj77's Avatar
no boosted car builds boost in neutral, u need to be under load to build boost, unless u got antilag tuned into the ecu, then u can build boost in neutral.
Old Oct 21, 2010 | 12:30 AM
DavidW's Avatar
some boosted cars must boost in neutral, haven't you heard a car rev then you hear the blow off valve
"brrrr pshhhhhh"
ecot3c inside's Avatar
brake boost, why would you want boost in neutral?
Old Oct 21, 2010 | 12:31 AM
"brrrr pshhhhhh"
like the srt-4's where the bov is used everytime you let off the gas, revving is giving it a load.
Old Oct 21, 2010 | 12:32 AM
Garret's Avatar
OP you should learn how a turbo works. They are neat little things
Old Oct 21, 2010 | 12:35 AM
tomj77's Avatar
"brrrr pshhhhhh"
our cars do to if u listen really carfully, u dont have to build boost for it to blow off, its just getting rid of whatever air is in there. even driving around at -5 vac my car blows off when i shift. i reved up my talon in neutral all the time when i was working on it, bov almost knocked me on my ass, still alot of air pressure in there even without boost.
Old Oct 21, 2010 | 01:37 AM
Sp33dyG's Avatar
I think hes askin y our cars dont do this...
http://www.youtube.com/watch?v=IAlWDLG1how
Old Oct 21, 2010 | 01:59 AM
09BlueBaltSS's Avatar
I can get about .2 psi in neutral werd
Old Nov 9, 2010 | 01:28 AM
sponge14's Avatar
YouTube - Cobalt Turbo Spool
Yes, that was what I was asking.
Old Nov 9, 2010 | 01:31 AM
sponge14's Avatar
Please explain to me what I am missing here, someone posted a video of what I was asking about?
Old Nov 9, 2010 | 04:46 AM
Wangspeed's Avatar
Your wastegate is open, and there isn't enough load, so not enough air to spool the turbo.
Old Nov 9, 2010 | 07:42 AM
CudaJoe's Avatar
yes, no turbo car I know of boosts in neutral.. unless modified to do so.
Old Nov 9, 2010 | 07:52 PM
tomj77's Avatar
because he obviously has antilag tuned in, which causes the car to backfire like a bugger and builds boost in netrual. pretty much the same idea as the car uses to stay in boost with the nls.
its bad for the turbo and the motor in the long run.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
DocSvensk
Sep 27, 2015 02:24 PM
