Bullseye Power Batmowheel for Ko4
#301
Well of you are afraid of your motor blowing it's this grand idea called building it
I'm down for the wheel hopefully I can score a cheap used stok turbo so my car won't be down again to upgrade it
#303
WTF are you smoking GTFO. How much does a good exhaust cost again? And how much HP does that add? Yet, people waste money on it every day ... GTFO this thread if you don't like it.
#305
You'd be lucky for 20hp at the crank, just a guess. Batmowheels are designed to increase the flow and spool of the turbo. On big turbos they net 20hp perhaps at peak psi. To expect the same of a smaller turbo - I wouldn't count on it. Even with the batmowheel, most people will still be running the turbo way past its efficiency rating, creating heat, and popping pistons. It's not necessarily about power. These motors can handle power. They can't handle overboosting the stock turbo. High heat = High IAT2, High IAT2s = high chance of knock. High chance of Knock = boom. I'm not talking out my ass.
All i'm saying this wasn't deserving of a sticky yet, that's all. No attempt to offend.
#309
^^This. Raver, if you're so against the wheel, why are you even in here commenting? Especially since you are saying what it will or will not do, meanwhile no testing results have been made available yet.
#311
I remember a thread one time about a BNR 2871GT that everyone doubted even after Drew posted Mustang dyno numbers.
But to the guy saying its not worth it, it is when you can get a K04+ for $400 instead of $1200.
Anyways most of you guys get to caught up in peak hp/tq numbers instead of hp/tq improvements through out the entire power band.
#313
#315
#316
and i mean people are complaining about $400 for something that is going to give you proven improvements in the car but you really think they are going to be quick to guarantee a company thousands of dollars.
people are starting to come around with our cars its just going to take time you have zzp developing kits, BYT is coming out with the bolt on 30r kit, and pretty sure their will be others
#317
holding them accountable??? they never promised anyone a kit. they promised they would produce a kit, which they've done and completed. there's nothing to "hold them accountable" for. all they're waiting on is BW to catch up on production.
#318
So for $400 if you can get something that will give you 2 more lbs a min it isn't worth it? If it increases the power output by 20ish whp it isn't worth it?
Who knows though, we don't have results yet.
#319
Whats interesting about this comment is that while an exhaust may not add as much, it would probably take 1/10 of the time to install. For those who would pay a shop to do the install, that adds quite a bit to the cost. Even if someone doesn't use a shop, it's still a lot of work.
#321
well zzp can't deliver a turbo that is in extremely high demand the issue comes from borg warner and not specifically from zzp, i mean zzp just got their car done not too long ago. the same reason why the stock k04 is hard to get your hands on brand new
Bolt on 30r? What garret turbo specifically?
