CAI to SRI Retune Needed?
Old Apr 14, 2015 | 04:23 PM
LTBALTBMX's Avatar
My car is a Trifecta tuned on a CAI right now, but I'd like to switch over to a SRI so I don't have to worry about hydrolock. The ricer inside me also wants to hear the BPV dumping air. Do I need a retune?
Old Apr 14, 2015 | 04:43 PM
umrdyldo's Avatar
Just monitor your fuel trims before and after and see how off it is. If it's +/- 5% then I wouldn't retune.
Old Apr 14, 2015 | 05:25 PM
LTBALTBMX's Avatar
If I need to retune then I don't intend on doing the swap
Old Apr 14, 2015 | 05:31 PM
umrdyldo's Avatar
You will be fine. Just go with the K&N SRI and don't worry about it. Trifecta already runs rich so i'm sure your tune will be safe as hell.
Old Apr 14, 2015 | 06:07 PM
LTBALTBMX's Avatar
If that's the case, then an SRI will probably make it run even richer. Is the ECU not smart enough to compensate for the loss of air mass?
Old Apr 14, 2015 | 11:36 PM
umrdyldo's Avatar
You are assuming the difference in temp is major. While moving the intake temps are similar. Especially after turbo after intercooler
Old Apr 15, 2015 | 12:03 AM
Sl0wbaltSS's Avatar
You're fine.
Old Apr 15, 2015 | 08:12 AM
LTBALTBMX's Avatar
Thank you both. I'll see if I can buy an SRI locally so that if it doesn't work then I can return it.
Old Apr 15, 2015 | 09:45 AM
umrdyldo's Avatar
Buy one and just resell on here. Only lose a few bucks.
Old Apr 15, 2015 | 10:57 AM
LTBALTBMX's Avatar
Yeah I may do that if I end up deteriorating the unit beyond reasonable condition.
On another note, what is the best way for me to monitor STFT and LTFT? Are these part of the standard OBD diagnostics protocol or are they a part of GM Enhance diagnostics?
If they are standard then I plan on writing my own datalogging software in Matlab to interface with my Trifecta black box.
Old Apr 15, 2015 | 11:21 AM
tomj77's Avatar
U don't hear the bpv with the cai? Weird I did. Anyway trifecta tunes suck with fuel trims anyway usually decently out, so I'll actually probably improve then with the switch
Old Apr 15, 2015 | 11:22 AM
LTBALTBMX's Avatar
I hear it, but I want to sound like a supra
Old Apr 15, 2015 | 11:34 AM
umrdyldo's Avatar
Cheapest way is Bluetooth adapter + Torque App for Android. Less than $30 total.
Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive
http://goo.gl/XGh6V
Old Apr 15, 2015 | 11:58 AM
LTBALTBMX's Avatar
Cool thanks. Now Im pretty confident I can do it with my blackbox and Matlab. I'll first need to figure out the PIDs though.
Old Apr 15, 2015 | 12:44 PM
tomj77's Avatar
Haha lol then u need forge bpv with stiffer spring on stock turbo
Old Apr 15, 2015 | 12:46 PM
umrdyldo's Avatar
You should be able to use the Torque app and edit the PID's. Should give you an idea of the inputs necessary for each PID
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
nathan112i
Sep 30, 2015 07:12 PM
Iceberg
Sep 29, 2015 12:33 PM
Sep 27, 2015 08:53 PM
