car is back
car is back
alright i know some of you will remember me as the first guy to blow a turbo in a lnf. well i was also the first to blow 3rd gear on a lnf as well 2 months after i replaced my turbo. well she is back again just finished my test drive car is running strong and damn did it feel good after 3 months of it just sitting. i sure as hell hope this is the last time i pull something major out of my car in my garage haha......thanks for everyones support
i dont wanna talk about it haha
i dont have any problems with the flywheel. it revs alot faster but thats it
Its just a matter of time before it pops another one if your pushing it beyond 25 psi. At 25 PSI the turbo on the LNF is running at about 100% of rated turbine shaft RPM limit. Guys pushing them higher than that with some aftermarket tunes are way beyond the max RPM rating of the turbine wheels and shaft. Don't expect them to last long in many cases. Jus sayin.
I am a GM engineer my opinions are my own.
a piece of metal from where? My bad I assumed you were running that tune thats spiking the turbo into the 28 LB range.
Just as an FYI the turbine is turning about 300,000 RPM ar 25 LBS. Thats the upper limit on the turbine shaft. beyond that is asking for trouble
Thanks for explaining that haha you always beet me to explain the problems with my car....is it bad that its happend so many times hahaha.....if it aint breaking your not driving it hard enough right???
Turbo Johnny
Feb 21, 2019 09:41 AM
NoBalt123
Sep 4, 2015 07:10 AM
