Car Wont Start Help!!!
Ok, I don't drive my car in the winter months. I have it covered sitting in the driveway but i start it every 2 or 3 weeks and let it run a while. Today I tried to start it up and when i turned the key it had prob turning over. I kept trying and finally it sounded like it was going to start it started and ran for about 5 sec and died. even when i tried to rev. it the car putted and shut off. It sounded like a loud bang when i tried to get it to start running and the motor was shaking all over the place.I also looked under the car because it did not smell right and the pipe before the Cat converter was red and hot! I took the batt. out and put it on a charger and put it back in the car but still did it. All the lights and stuff work on the car and the chimes. I also installed a AEM Intake and I know i hooked it all up right it was very easy but still nothing. I cant get the car started and its annoying me big time. Please I need help I cant get it started and I dont know what to do!!!!!
did u plug it in for an hour or so before u started it? synthetic oil or not, left that long without starting in the cold, then trying to start it isnt good for it.
I dont see any animals or nest and none of the wires look like then been chewed through. Also the maf oriented only goes in one way right because when you put it in the whole the screw holes only match up one way. it sounds like it tries so hard to start and it sounds like a tank is coming and only start up for a sec.
And yes i left it sit on for a day on a slow charger and I know it sucks i try to start it up as often as I can and its just reg oil.
Last edited by Thelegend050; Jan 16, 2010 at 10:03 PM. Reason: Automerged Doublepost
once at work i didnt plug in my car, it got to -30 and even with sythetic oil, when i started my car, i thought it was gonna fall apart it vibrated so bad.
Hmmm.... with the exhaust getting red hot like that it sounds like WAY too much fuel in there for some reason. It was probably burning in the exhaust as well and having trouble igniting because of not having enough oxygen for the amount of fuel in the cylinders.
That's my .02 anyway. Because neither the battery being low OR being so cold would cause the exhaust to get red hot like that. Unless maybe the cam phasers being so starved of oil allowed the already burning mixture to escape. That could be too I suppose.
Has it started yet? If so, ran ok now?
I still cant get it started and is still doing the same thing. It smells like something is burning thought. i checked the oil in the car and it looks fine. I put it away Nov. 1 and i tried to start it like every other week for about 30 minuets or so. The Batt. should be fine its a 2008 and has never had a prob with the Batt. I'm running out of ideas what to do.....
I'd just call up the dealer, explain to them it won't start. Tell them to come tow it and figure out what's wrong.
Do you still have warranty? I have an 08 and passed the 36K bumper to bumper already.
I have a CAI thats all nothing else done to the motor yet but it is still under dealer warranty so well see if i can start it tomorrow. I put some gas anti freeze in it and it putted a little bit longer so well have to wait for tomorrow and see. Thanks everyone for all the help
check ur ECU. make sure no water or anything got in the wires that go into the ECU. If its that cold in your garage. just in case. check ur plugs. go over things that can make a rough idle like that. reg oil is no good. full synthetic man. what octane you have in your car? check nothing got into your turbo. any oil leaks anywhere?
just going over ideas.
put it into a warm place and then see what happens. the other day i got snow in my forklift intake, it wouldnt start after that, tried to turn it over and over, then there was a loud ass backfire that made everyone **** their pants in the shop, and still nothing. turns out the spark plugs were wet from the snow and blew out. changed em, ran rough for a bit, then it ran just fine, try changing the spark plugs and see what happens.
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
