Cardelino18 Motor Build
That's my cup of spare cobalt bolts. That, and several ziplock bags. I used to have a thinner, taco bell cup, but it split open one day. The Flanagins cup's are much stronger
They're also a good size to hold head bolts, whatever. I have a couple around the garage for specific purposes.
Do yourself a favor, get a repair manual for the car. It will detail those kinds of things for you. Believe me, you don't want to mess up the timing. A very small mistake can cause a ton of damage to your motor.
How did you take of the timing chain Did you just take it off with out marking it? Because im helping a friend with his build and if you don't put the the timing chain on right the car is not going to run right. So im just asking what yall did to know how to put the timing chain back on right.
well here is an update of parts and how the build is coming along...
my new tranny mount
a really fast polish job that i did to my valve cover
Treadstone Performance Intercooler Kit for the new turbo upgrade:
New Treadstone Performance Cold Air Intake for the turbo upgrade:
Darton Sleeves (this is not my motor)
to make sure everything work good i got a dashhack
motor should be back and ItalianJoe1 shop late this week/early next week... if everything goes well should have my car back by next week!
my new tranny mount
ok so tonight we will be doing the final touches to the motor... its already in we just need to do the re-learn on the camshaft and make sure everything works out well... here is a pics of my new gauge set-up with my dashack insntalled on the AC vent
#40
Either way the motor should be pretty nasty!
#44
ok so i though to give an update on my thread....
motor is done... drives perfect! the only problem now is that i blew my turbo today... talked to Jason at Treadstone and the turbo kit should be ready to get installed in less than 2 weeks...
this is my plans for next year:
Valves
Valves Springs
Retainers
Port & polish head
Corrillo Rods (however you spell them )
tranny upgrade...(lets see what zzp comes out with or just build a G85 tranny)
SPEC stage 3+ or stage 4 clutch and flywheel
Meth kit
after all that well see how the car turns out.... keep in touch!!
Valves
Valves Springs
Retainers
Port & polish head
Meth kit
#46
Valves
Valves Springs
Retainers
Port & polish head
Meth kit
Valves
Valves Springs
Retainers
Port & polish head
Meth kit
Lemme know when you're ready to do more work on it, i'm always down.
ThoR294
10-04-2015 08:44 PM
