Check Engine Light....OH NOOOOO
Old Mar 2, 2010 | 10:25 AM
importkiller's Avatar
So, I put my AEM intake back on without the foppy elbow and used the stock one instead, I have been driving fine for the last 2 weeks with it on, and it is spiking up to 23-24psi. Last night I turned on to a nice highway with a acceleration lane that is about half a mile and I floored it in second and nothing happend, the car boosted up to about 5 psi and no further. I turned off the car at the next stop light and it started boosting again but it would lag till past 5 psi. A mile later down the road the check engine light came on. I called onstar to request what it was indicating, they said it said there was a problem with the air intake system. I got home popped the hood and first of all the rubber thing that holds the charge pipe down was broken but other than that all the clamps were secure no visible leaks or problems. I disconnected the computer to reset and then reconnected but i still have a check engine light.
WTF
Old Mar 2, 2010 | 10:45 AM
Iam Broke's Avatar
When the CP came loose of the mount, did it crack?
Stop at AutoBone & get the code read.
Old Mar 2, 2010 | 11:55 AM
i did not see any cracks, I am gonna try to get over to autozone today.
Old Mar 2, 2010 | 11:57 AM
run the car thru a few key cycles
Old Mar 2, 2010 | 01:13 PM
should I just give up on this AEM POS and use the stock box...That is what I am thinking.
Old Mar 2, 2010 | 04:07 PM
cardelino18's Avatar
take the negative plug off the battery and leave it disconnected for about 30 seconds, that would clear the code(s)... it will run fine but it might happen again until you fix the problem, find out whats the code but for now just unplug the negative side of the battery for 30 seconds and put it back on...
Old Mar 2, 2010 | 04:08 PM
Schullz51's Avatar
I've blown off that rubber piece to the charge piping too. It didn't break but I popped my Hood open and my CP was all floppy and at a weird angle. It didnt give me a CEL though
Old Mar 2, 2010 | 04:37 PM
My best hypothosis is that when the pipe popped off it twisted the rubber connectors funny and caused a choke in the system thus throwing off the air readings between the MAF and the MAP sensors. I will say the AEM CAI does make a difference on a tuned car.
Old Mar 2, 2010 | 08:03 PM
Schullz51's Avatar
I definitely think that could have happened. Im not sure what causes the CP to come off it either has to be the CP swelling cause of the increase in boost going through it, my other hypothesis is that the engine is rocking just enough to put strain on that rubber thing. I found mine was off after checking a much bigger problem, my tranny pretty much blew up haha.
Old Mar 3, 2010 | 12:22 AM
Argg could not make it to Autozone today, maybe tomorrow.
Old Mar 5, 2010 | 09:57 AM
Well I put the OEM full intake back on and the CEL went away...the car feels slower than with the AEM but it is worth it for drive-ability.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
