Clear Image Automotive dyno testing, flow bench testing and more...
Old Mar 3, 2009 | 11:52 PM
  #526
Mazdaboi318's Avatar
Originally Posted by Chandler
So why do people get the GTTuner and not just the cable, seems if that you are going to constantly upgrade, then there is no point to the tuner except if you are going to flash it only once. I am sure that the cable wont sync with my ECU , if that were the case , Vince would sell 2 tunes and there would be 50 cars running around with that tune. no Bueno for biz.
The tune and the cable are together $500 with 250 tune + cable 250 ???
One reason = People like me who have Mac computers and cannot use the cables/software.
im not understanding what you are asking.
for 250 you get the GT tuner and Tune shipped to your house so you can upload it.
It is less if they only send you the cables and software for you to upload.
Old Mar 3, 2009 | 11:55 PM
  #527
elecblue06's Avatar
Originally Posted by madlion
I doubt the cable is 250.. maybe like 100 can anyone chime in on the cost of the cable. im in norfolk, va from the poster above are you near me?
1. can you data log with the wire or does only trifecta/clearimage have access to that?
cable is 250 because it comes with a tune... the cable lets you do everything the gt tuner does.. cept you don't have to return it and you can use it to flash other people
Old Mar 4, 2009 | 01:06 PM
  #528
madlion's Avatar
so the cable and tune is $250 total and you get to keep the cable???
Old Mar 5, 2009 | 12:43 AM
  #529
elecblue06's Avatar
yes sir this allows you to go back to stock tune at any time and for easy reflashing / loggin.. long as you have a laptop lo
Old Mar 5, 2009 | 10:53 AM
  #530
Nakaiya21's Avatar
Whoa...wait a minute...the tune is 250 and the cable is an additional 200 (might be 250)...check out the clear image automotive website for more information and the order form....
By the way the incentive to getting the cable will be to go back to stock as well as incorporate other tunes for your vechile (Vince is looking to make additional tunes for $50+ each in the future)
Old Mar 6, 2009 | 04:16 PM
  #531
Psytocrophic's Avatar
I find your site a bit confusing.
for one i dont know where to order lol.
Also, can you give me a price for the full 3" exhaust system, and 3" DP, stainless steel, with cat back
Old Mar 6, 2009 | 11:40 PM
  #532
ClearImageAuto Dan's Avatar
To answer a few questions and clarify a few mis-conceptions.
3" boost tubing would be complete over-kill with the stock or even a larger turbo. 2 1/2" is going to support more power than most anyone will ever have. 3" would also be an issue to install as 2 1/2" is already tight. And, though it does fit under the hood, it would be using all available space.
The reason for a larger down-pipe and exhaust is to reduce back pressure. This allows the turbo to spool quicker and run more efficiently. The boost tubing size does not have to match the exhaust, as the air going into the engine is being compressed where as the exhaust is being allowed to flow freely.
The data cable costs $200.00. It actually uses a microprocessor to allow communication between the cars PCM and your laptop.
Tuning is NOT included in the price of the cable.
Quick break-down:
data cable - $200.00
TriFecta tune - $250.00
shipping - $35.00
50 HP to the wheels - PRICELESS
For those wanting to purchase the data cable, additional tunes are available for $100.00.
As for the website, yes, it is hard to use right now. We are hoping to have it completely re-done very soon. To order, we still require you to call: (425)251-0329.
Thanks again everyone.
Old Mar 7, 2009 | 03:03 AM
  #533
cobaltssoverbooster's Avatar
3" charge piping would cause a slight lag in pressure build over the 2.5"
more space the air has to be compressed in means slightly longer time to build pressure. 2.5 should flow fine to 500whp or very close if not more. def overkill as stated on the 3"
3" charge piping is more of a large ci motors application and for pure strip applications on smaller ci motors with full custom builds
Old Mar 7, 2009 | 10:58 AM
  #534
Terminator2's Avatar
[QUOTE=ClearImageAuto Dan;3567575]To answer a few questions and clarify a few mis-conceptions.
That makes sense. 3" would probably cause more lag than 2.5" And we probably dont need to flow 700+ CFM unless there is a GT40R under the hood.
Old Jun 28, 2009 | 10:39 PM
  #535
Cobalt Fury's Avatar
how do you order this tune??
i did this,
https://www.trifectaperformance.com/...r/default.aspx
but how do u pay?
Old Jun 28, 2009 | 11:13 PM
  #536
they will contact you...
Old Jun 29, 2009 | 03:43 PM
  #537
Thanks for your order. Sounds like Alicia already called you.
Old Jun 29, 2009 | 04:23 PM
  #538
Donny Brasco 2's Avatar
Dan,
Any update on the short ram?
Old Jun 29, 2009 | 08:35 PM
  #539
Originally Posted by Donny Brasco 2
Dan,
You mean this?
We finally got the prototype kit built Friday and installed it on our customers car. He has not had any problems; no codes, engine lighte, driveability issues, etc.
Here's a close-up of the PROPER breather valve connection:
I'll be starting a thread in the vendors area as well as a teaser in this area.
Old Jun 29, 2009 | 08:39 PM
  #540
umrdyldo's Avatar
That is crazy looking.
Old Jun 29, 2009 | 08:42 PM
  #541
marcusicp's Avatar
Originally Posted by ClearImageAuto Dan
You mean this?
Sell me the first one!
Old Jun 29, 2009 | 09:19 PM
  #542
alger388's Avatar
is there any pros/cons using a short ram over a cold air?
Old Jun 29, 2009 | 09:26 PM
  #543
Donny Brasco's Avatar
Dan - once again thanks for stepping up!
Datalog that thing and see if the fuel trims are stock.
Old Jun 29, 2009 | 09:47 PM
  #544
ninja44's Avatar
Yeah I'm curious about the fuel trims as well. I'm sure everybody would like to see them to make sure they aren't out of whack before jumping on the bandwagon. Thanks again Dan!
Old Jun 30, 2009 | 07:36 AM
  #545
CudaJoe's Avatar
lets see some number!!!! dyno time!!!
Old Jun 30, 2009 | 09:43 AM
  #546
wantedSS/TC's Avatar
he stated both the cold air and short ram provided 15/15 to the wheels
Old Jun 30, 2009 | 02:52 PM
  #547
Cobaltss/TC's Avatar
I have been talking with dan and the fuel trims are dead on normal stock, no issues.
the test mule is still driving with it has been on since friday and no issues yet.
Old Jun 30, 2009 | 03:07 PM
  #548
I'll be working with Vince for data logging this week.
On the Tech 2, our customer monitored a difference from -3 to +6 on the fuel trims at WOT and -14 on the long term. No codes, engine lights or driving issues. Let's see what data logging shows.
Thanks all.
Old Jun 30, 2009 | 03:58 PM
  #549
Thanks all.
-14 LTFT is way off!!! another 4-5% and you will throw a rich bank1 code.
Stock LTFTs are close to zero most of the time. -14LTFT is way off. Mine were -9 to -11 with my Dejon SR intake and the car runs tons better with the stock airbox and the fuel trims are much closer to zero most of the time. THE HOT IAT1s are causing the ECM to pull tons of fuel. The CAI should test much better. LTFT should be within 5% of stock not off by 13%.
Last edited by Terminator2; Jun 30, 2009 at 04:01 PM. Reason: Automerged Doublepost
Old Jun 30, 2009 | 04:07 PM
  #550
Well, considering the length of the tube in the short ram intake, there isn't going to be any way to change the position of the MAF. The cold air intake may be the best way to go.
We are working with another customer on a custom project. We will be relocating the MAF to the cold boost tube before the throttle body. We'll see what happens.
