Clear Image Automotive dyno testing, flow bench testing and more...
Old Jan 11, 2009 | 10:17 PM
  #76
kling1022's Avatar
Yes. I will explain it the best i can here. They send you something called a GT tuner. You tune the file onto you ECU. Then you data log it which means you just run off the numbers on your computer such as A/F ration, Spark, and what not. Then you send this data log to Vince and he fine tunes it when sends you an update tune. So yes he optimizes your mods. Very cool
I do not have this tune yet but understand how it works. IF you have any more questions feel free to ask.
Old Jan 11, 2009 | 10:19 PM
  #77
sheldon729's Avatar
can the amount of boost ran be suggested too? And they make sure that the "learn Down" is gone correct
Old Jan 11, 2009 | 10:21 PM
  #78
kling1022's Avatar
oh yes. Just tell Vince you want a certain amount of boost. He can customize the tune to do whatever you want it to do
For instance some people have suggested to keep the torque around 330 to keep the clutch from slipping
Old Jan 11, 2009 | 10:24 PM
  #79
sheldon729's Avatar
Thats awesome...Mmmm 25psi. i was snooping around clear images website and couldn't find the tune for the ss/tc so not able to order quiet yet i take it. Next question is to log the data and send it back is it just idling data cause driving data wont be all that great seen as its winter and -15F with about 2 feet of snow.
Old Jan 11, 2009 | 10:27 PM
  #80
kling1022's Avatar
yes idle i do believe and yes you can order it now. Just put any model of cobalt then in the comment box before you order put ss/tc and the year of your car. Trust me you can order it. I did but then had to cancel it because i realized I ran out of money lol. THey were ready to send it to me and everything. So yes you can order it
Old Jan 11, 2009 | 10:29 PM
  #81
sheldon729's Avatar
no codes are set and the sensors are fine?
Old Jan 11, 2009 | 10:37 PM
  #82
kling1022's Avatar
I dunno quite what you mean. If you mean does it set of a CEL then no. And 25psi might be pushing it. I know he can do 23-24 psi but that's damn close. I've heard over 23-24 psi isn't possible without the gm stage kit to update the sensors
Hey Taylor i think i need to get a sponsership for all this lol j/k
Old Jan 11, 2009 | 10:39 PM
  #83
sheldon729's Avatar
so ur not to sure what the dyno illistrated above was running for psi cause if i can hit 300hp+ easy and 330tq+ easy i would be satified if it was only running the psi needed to reach that if it was only 20 or 23 haha
  #84
Cobaltss/TC's Avatar
Ok guys i have the tune and i am running 21.75 as seen on that dyno sheet, anything over 22 psi can cause serious damage to the trubo, it will begin to surge, at 23psi i belive the wastegate opens because the spring can no longer hold the pressure, when i boost i hit 24-25psi spike then settles smoothe to 21 psi. Vince will not be going over 21 psi for the reason of clutch slipping, we tried 23Psi on mine and sure enough the clutch slipped in 4th and 3rd around 3500rpm!!!
Old Jan 11, 2009 | 10:44 PM
  #85
kling1022's Avatar
ahah i was about to say i believe it was around 22 psi. lol beat me to it
i got some info from that guy who has the screen name copson or whatever. He lives like 10 miles away from me
and he uses this GT tuner and tunes for Vince
Old Jan 11, 2009 | 10:45 PM
  #86
hatrickstu's Avatar
i have your 4-2-1 header. i love it. lol
  #87
sheldon729's Avatar
So that dyno'd plot posted earlier is on ur car and ur running 21psi after a jump to 23psi. What supporting mods u running exactly.
Old Jan 11, 2009 | 10:50 PM
  #88
kling1022's Avatar
I believe just an SRI.
Old Jan 11, 2009 | 10:52 PM
  #89
NONE JUST TUNE!!!!
Old Jan 11, 2009 | 10:53 PM
  #90
kling1022's Avatar
oh wow. I'm in love. I need money so bad right now damn it lol
Old Jan 11, 2009 | 10:55 PM
  #91
sheldon729's Avatar
So taking a guess what kinda qains would i see with the mods i currently got ---> Hahn CAI, Straight 3" turbo-back exhaust, intercooler piping
Old Jan 11, 2009 | 10:57 PM
  #92
kling1022's Avatar
atleast 325 hp
That downpipe really makes the difference, especially a catless downpipe
Old Jan 11, 2009 | 10:59 PM
  #93
yeah and would probably want to look into a new clutch like me!!!! I am getting the SPEC stage 2+ clutch, since i can install my self that is a cheap option
  #94
sheldon729's Avatar
it is catless.. for $250 cant go wrongs this is a big bang for ur buck. Im getting it
As for clutch come spring i am installing a Exedy Stage 3 (Hyper-Single) Clutch/flywheel combination as long as i find one to fit turbo Application
Old Jan 11, 2009 | 11:01 PM
  #95
kling1022's Avatar
$250? where did you get it from?
oh lol my bad. I thought you meant the downpipe. I take it you have the synapse downpipe
Old Jan 11, 2009 | 11:03 PM
  #96
08BlackSS/TC's Avatar
First of all, I have to say great work Dan!
Yes get a new clutch but you shouldn't need to worry about it as much. My stock clutch still has NOT slipped with the GT3076R upgrade.
Old Jan 11, 2009 | 11:05 PM
  #97
sheldon729's Avatar
08BlackSS/TC
What u running for hp and Tq
Old Jan 11, 2009 | 11:16 PM
  #98
Thats good to hear, have you put yours on the dyno? mine was slipping there well starting to, but vince being very careful he let off
Old Jan 11, 2009 | 11:17 PM
  #99
08BlackSS/TC
Not sure yet but I'm running 40lb/min, technically close to a number around 400. Not sure when I'll be getting on the dyno.
it tends to slip when the tune seem to hit its peak TQ around the 3-4K RPM mark, past that it doesn't seem to
Last edited by 08BlackSS/TC; Jan 11, 2009 at 11:17 PM. Reason: Automerged Doublepost
Old Jan 11, 2009 | 11:19 PM
  #100
Yeah that was the same range mine was slipping, i hit 3500 rpm and you could hear it, dyno showed the same thing. I think Dan could be able to show where it was slipping he has all the dyno runs.
