Clutch pedal sticking to floor
Last night I was driving and when i went to shift the clutch pedal sank to the floor and I couldnt go into any gear. i=I had to clutchless shift all the way home I have a ky stage 3 clutch that was installed about a month ago. what could this be?
^this or you just lost all of your fluid due to a line failure (if there was a line failure of any sort it would more than likely happen where distribution block meets the clutch pipe). How does the brake pedal feel? Have you checked the fluid reservoir?
Best,
Sarah
GM Customer Service
You don't want to hear this, but we make 90% of our own problems. I don't exactly what could have gone wrong with the installation because I still have yet to try this, but something likely did. Either that, or the stock TOB couldn't handle the resistive pressure given by the pressure plate.
Either way, sorry about you bad luck. Now you have to pull it all back apart again. I'm hoping you didn't end up with fluid all over your clutch plate.
