Clutch questions...
Clutch questions...
Soo my clutch is starting to slip when running my tune (I expected this, gotta pay to play) My question is, what clutch do you guys recommend? My mods are in my sig, I also plan on intake, pipes, MXp exhaust, FMIC, and not to sure what else.
I'm not to concerned with chatter and stiffer than stock feel, If I have an extended drive in traffic I have and auto for that, or I can suck it up I've my share hard clutches before.
Thanks for the input guys.
-Alex
-Alex
Stock clutch here, course I'm running a tune that's barely more power than gms1 haha... Check out the ZZP clutches, they have one for just about every kind of style of driving you want.
-Alex
-Alex
Look for the clutch threads in the Drivetrain section. I posted a lot of info there in the past on my SPEC Stage2+ & LW flywheel.
ZZP you will want a Stage 4+ for tuned torque. Search is your friend.
I was considering the ZZP Stg 4 or the MPx kits.
-Alex
ZZP Stage 4 would be my choice if I had to do it over and keep the stock FW. The SPEC 2+ chatters a bit cold and the LWFW takes some getting used to. Replace the slave cyl & throwout bearing when you are in there.
