Clutch slip
Old Aug 24, 2011 | 08:38 AM
mongorat427's Avatar
Originally Posted by VandykeT/A
i've always shifted at 2k rpm and when trying to save gas lugged the car around but i don't always just floor it in high gear. Every other car I own is a manual. I've got a 452 rwhp Trans Am and its had the same clutch in it for over 20k and never had a problem but as long as I don't let the cars rpms drop down and get on it does fine. I'm just gonna drive it until I can get a new one and see what happens.
If you shift at 3000 rpm your clutch will last longer. There was a writeup on this awhile back.
Old Aug 24, 2011 | 08:42 AM
Make sure you break the new one in for 500 miles of normal driving and throw an upgraded LNF slave and new pipe in while your at it.
Old Aug 24, 2011 | 09:30 AM
AARON-SS-TC's Avatar
i shift @ 3k in town and usually end up in 4th most of the time, and i cant get better than 17mpg. So i am gonna start keeping the revs up higher and then shift and see if keeping it in boost gets better gas mileage, but i doubt it.
as far as punching it in 5th @ 2k, why the hell would you wanna do that?
oh well, get a zzp or gmpp clutch and break it in properly and you should be good.
BTW, isnt our stock clutch only good for 320wtq?
Old Aug 24, 2011 | 09:54 AM
RHZ's Avatar
RHZ
when i cruise in 4th gear at 2800 RPMs unless i'm going uphill i get 35-37mpg.
Old Aug 24, 2011 | 05:44 PM
1971/2009 Chevy's Avatar
Ok i just went out there and changed it and it was a light brown. Maybe a slight bit darker than urine. I drove the car down the road not giving it alot of fuel below 3k and it seemed to hold find it started raining so i couldn't really do much. Since its started this its probably best that I don't beat on it until I get a clutch or just keep riding it as always and not give it alot of fuel in high gear. I don't want to be afraid to run it hard.
how did no body flame this? change your fluid to help your clutch? maybe if it was not disengaging... but for slipping? what has this forum come to..... i cant believe that css.net is giving out bad info again
Old Aug 24, 2011 | 05:49 PM
Mike08ss/tc's Avatar
Originally Posted by princessturbo
mines starting to smell now as well ever since i got it running 100% then i added e to the equation .
Then this little thing called a cold front came through one night ...
Yup it's dead...
Clutch masters vs zzp clutch whats your guys guess
zzp
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
