Clutch slip in 3rd 4th and 5th under boost... sooo
Old Feb 9, 2012 | 11:41 AM
MajorCB's Avatar
so I'been getting some clutch slippage since the HP tune primarily in 3rd and 4th...I'm thinking about the possibility of a clutch upgrade... Im NOT looking for one that feels like pressing on a 30lb weight... so what's the best for cheap... or , is it more feesable to head back to the dealer...wipe out the tune and go back to stage 1 and take it in... thoughts?
Old Feb 9, 2012 | 11:43 AM
Chevycobaltss3's Avatar
Click on my Sig.. great prices and great pedal
Old Feb 9, 2012 | 11:49 AM
Permafried-'s Avatar
What RPM range?
Old Feb 9, 2012 | 11:51 AM
MajorCB's Avatar
hey thanks for that.. I'll definately check it out.. have you used the stage 2? is it fairly easy to engage? or is it heavy... I hate a heavy clutch... I drive city more often so Im not looking to have a incredible hulk left leg and fall over when I get out to walk lol
and as for the RPM's 3000- to about 5500..but primarily under boost where the TQ really picks up...
Old Feb 9, 2012 | 11:56 AM
Frogstofall's Avatar
Trying to take it in wouldn't do you any good anyhow. They don't warrany clutches, it's a wear item. It'd be like trying to get them to warranty your break pads.
user 70823082's Avatar
How long has it been since you've had your tune?
Old Feb 9, 2012 | 11:58 AM
SlowMs3's Avatar
Yea my clutch started slipping a bit after the tune. But only under like 3k.... if im in 1-2-3 2500rpm or above and punch it its fine but i havent tried 4th... but i tried 5th because someone else told me about the clutch slipping after his tune and boom 2700rpm in 5th gave it some and slipped alittle.... i haven done since and i wouldnt do it at all anyways but kindof sucks..
Old Feb 9, 2012 | 11:59 AM
You guys do realize that your clutch is going to glaze over and eventually stop slipping right? I dyno'd at 402 WTQ on the original OEM clutch my car came with.
Old Feb 9, 2012 | 12:00 PM
With the lnf I don't recommend anything under the ky clutch stage three. Pedal pressure is very minimal.
Wait.... Wouldn't glazing make it worse?!
Old Feb 9, 2012 | 12:01 PM
Lulz, I have people on a stock clutch that dynoed 440-450 ft lbs. It's the fact of how long it lasts.
Glazing is what causes your clutch to slip..
And yes glazing actually what causes the slippage mainly
Old Feb 9, 2012 | 12:02 PM
Gremlin85's Avatar
Def KY Clutches. Just installed mine (Stage 3) yesterday and the pedal feels like nothing. It's so light and easy to press. Very little chatter when cold and after a few miles of driving it engages like stock with 0 chatter.
Worth every cent.
It's easy to make a tune and not have a slipping clutch, its all about boost ramp. Some like it some don't.
Old Feb 9, 2012 | 12:05 PM
This is why I asked. His statement is confusing...
Old Feb 9, 2012 | 12:06 PM
Yes it is lol.......
Old Feb 9, 2012 | 12:07 PM
MajorCB's Avatar
yeah I was under the impression that once the clutch develops flat spots, that its a permanent thing and will only make the slipping worse over time... and as for bringing it in, I appreciate that note... I thought it might be covered under the powertrain... I've had the tune for about 4months...I dont really work the car over much at all to be honest.. I realized fast that 2nd gear is kinda raunchy when I got on it.. so, I did some decent pulls from 40-90mph in 3rd a few times and really started noticing it only in the last 2-3weeks.. I wasn't sure if was colder temps.. but I thought that was really not the case with this issue... so I've been weighing my options...
Old Feb 9, 2012 | 12:09 PM
MajorCB's Avatar
thanks for the post gremlin... good to know
Old Feb 9, 2012 | 12:10 PM
Dart_SI's Avatar
To keep my clutch from slipping I never go WOT under 65mph in 3rd. 2nd is ok cuz all it does is spin. I have at least 380-400 wtq and the stocker is holding up.
Old Feb 9, 2012 | 12:13 PM
MajorCB's Avatar
Worth every cent.
hey what kind of power are you putting down.. just curious
Old Feb 9, 2012 | 12:14 PM
SlowMs3's Avatar
Yea thats what i told the Mrs.(since its her car) If your going to punch it, punch it above 3500rpm in 3rd.
Old Feb 9, 2012 | 12:15 PM
yea mine doesn't slip anymore lol...
i've heard gmpp clutch is good for pedal feel and 300 wtq. i'm gonna get that one.
even if its not slipping anymore its still probably not getting all my power to the wheels right
RHZ's Avatar
RHZ
That's your problem right there. You shouldn't be WOT in 3rd at 40 mph.
Old Feb 9, 2012 | 12:18 PM
Gremlin85's Avatar
Last dyno was 320ish whp and 383wtq. The stock clutch only slipped a little but it was noticeable - wasn't going ot last.
I had to replace my tranny anyway so while I was in there I did new stock flywheel, KY Stage 3 clutch and new throw out bearing. New mounts as well.
I plan on doing the EFR Turbo when it comes out so I'm already prepaired to put the power down
