Cluthch & Flywheel?
Old Feb 5, 2009 | 09:19 AM
Mazdaboi318's Avatar
Cluthch & Flywheel?
Anyone running new ones yet? How are they holding up?
Prices? Specs
Old Feb 6, 2009 | 12:08 AM
Old Feb 6, 2009 | 03:45 AM
sporttintturbo's Avatar
bumb x2 mines starting to slip. going to be looking in to one soon
Old Feb 6, 2009 | 01:43 PM
platinumrims's Avatar
so no one knows... going to h from what it sounds like imma have to buy a new one and idk wut to get... but i know that i want one that can handle 400whp... for the future lol...
Old Feb 6, 2009 | 01:46 PM
roadrage06's Avatar
how is your clutch slipping already?
I used to think mine was. Then I put new tires on for winter......................it was the tires.
You might want to be sure of that before you drop that kind of cash for a clutch.
keep in mind we live in PA, there is a ton of salt and **** on the road. Audibly, it can be deceiving.
Old Feb 6, 2009 | 06:56 PM
Bump for a clutch lol
sorry for the title mis spelled
Old Feb 6, 2009 | 07:48 PM
blu3_v1p3r's Avatar
Hey check out turbo tech racing... they just helped me decide who to buy with and what to buy... and great deals...
Old Feb 6, 2009 | 07:50 PM
08BlackSS/TC's Avatar
I have a SPEC Stage 3+ w/ Flywheel (rated to 550tq)
Old Feb 6, 2009 | 07:51 PM
blu3_v1p3r's Avatar
I'm going with spec stage2+ and flywheel
Old Feb 6, 2009 | 08:58 PM
WaRRioR-StaTuS's Avatar
how much power if the stage 2, and stage 3 expected to handle, it doesn't say on ttr's website
Old Feb 6, 2009 | 09:00 PM
Premier's Avatar
i also purchased a spec stage 3+ clutch and getting the flywheel here within the month. let you know how it holds up when i get it put in. . . . NEXT month. ha. damn this **** is EXPENSIVE.
Old Feb 6, 2009 | 09:29 PM
TurboTechRacing's Avatar
Many have went with the SPEC stage 3+ and aluminum flywheel on their SS/TC, it is a very nice setup. Never any complaints on it
If you have the 2.0 SC or 2.0 Turbo, we only recommend going with the "+" series setup. The clutch price is only half of it, the other half is the labor/time to install it. IMO I would rather do a clutch once, and have it "over sized" that way in the future when you add more mods, your clutch is not "under sized" and you are ready for it
Last edited by TurboTechRacing; Feb 6, 2009 at 09:29 PM. Reason: Automerged Doublepost
Old Feb 6, 2009 | 09:34 PM
QFT!
Old Feb 7, 2009 | 12:11 AM
How much for that nice set up?
Old Feb 7, 2009 | 12:15 AM
Close to $1200
Old Feb 7, 2009 | 12:16 AM
yikes...then u gotta pay for install...$1800 to hold 450 hp
Old Feb 7, 2009 | 12:17 AM
rated to 550tq and those ratings are usually underrated
Old Feb 7, 2009 | 12:19 AM
yea thats not bad...just expensive lol...guess ill be staying in the mid 300's for now
i want 11's so bad
Old Feb 7, 2009 | 08:46 AM
It is actually closer to $1000 (a bit above if I remember correctly)
Old Feb 7, 2009 | 10:36 AM
blacktc\ss's Avatar
Close to $1200
installed? or did you attempt.
Old Feb 7, 2009 | 11:17 AM
Premier's Avatar
i think the $1200 sounds about right for clutch and install. . . that's if you're resurfacing your flywheel. if you're buying a new flywheel you can probably add another $350-$420 to that number. might as well go all out now so you don't have to re-do it later.
Old Feb 7, 2009 | 11:26 AM
Around $1200 is for clutch and flywheel, yes. This isn't including install yet! Install is another $600!!
Old Feb 7, 2009 | 12:40 PM
Nakaiya21's Avatar
Ok...so 2K is not something I want to look forward to anytime soon....so my question is this: What can the stock clutch/flywheel handle? I can't seem to find this information anywhere....
Old Feb 7, 2009 | 02:05 PM
I would say 330hp 350 tq. Max
Old Feb 7, 2009 | 02:20 PM
blackbird's Avatar
Are you asking about aftermarket clutches or how well the stock unit is holding up? I'd have to check my time slips for an exact count but I should be close to 90 passes on the car and quite a bit of miles racked up. The stock organic disc gets a little soft when hot but has held up well, even at a couple really slow track days where I got north of 30 passes in (most back-to-back). I'm betting if you don't abuse it and severely overheat it ever that it will hold up okay at the expected GMPP upgrade torque levels. I'm not going to look into new clutches until (if) I get to a power level where the stock one is inadequate.
