Contacted APR
lol so in a sense one could use it as sort of launch/traction control so you cant hit full bust till a ways under motion..... hmm.
how much boost is made before surge occurs?
^^exactly...all thats needed for the k04 upgrade is a good tune.
in all honesty kappa vs delta is 2 different things like stated above. i wouldnt even say the delta chassis wants big hp. its more or so the cobalt guy that want big hp. ive yet to see an hhr with big power goals around here let alone a cobalt other then mine and 1 that zzp just finished other going for serious power. all in all you pay to play
It seems to me you do, as you can not produce any good dyno results of the K04+ on a cobalt ss/tc or hhr ss with the actual whp gains you claim. You just have speculation on what it might be on those platforms because the Kappa platforms uses the same engine.
Any ways good luck with your company (and college), I've proved my point countless times in this thread, offered to try it for you to post results to help validate your claims and you still want to be in denial about the K04+ on our platforms. Your not gonna budge on your thoughts as far as the K04+ on our platforms and neither will I, so its a dead end conversation.
And if your point is correct, than why would the HHR and Cobalt SS results all of a sudden be one in the same, since if its in a different designed engine bay, it would clearly be different by your argument.
If werks is makin so little on it (by his saying) that he doesnt even have wiggle room to give you a % off to actually try it off, than why would you expect them to have the money to use up a whole kit worth of money and time, with a small (and iffy) market.
I see both sides, i just dont understand why OP is driving home the point that since its a diff car its drastically different results. I dunno If i was sick I would take advice from a doctor, If i needed to build a shed id ask a carpenter etc etc etc... not sure how this is different....
Again, I'm happy the K04+ has all worked out great on the Kappa.
With that being said I want results from someone with a Cobalt SS/TC or HHR SS, the 2 people I knew that had the K04+ had problems, Hiltu who fixed his surge issue (I believe) but no new dyno results, and cobaltssoverbooster, who couldn't boost past a certian psi no matter what he did (is this fixed and does he have a dynograph).
Now have you or the place you work for actually built a k04+ for a Cobalt SS/TC or HHR SS owner? If so, tell them to post up about it, maybe some dyno graphs, otherwise known as proof of the claims on a Cobalt SS/TC or HHR SS.
I want real world results, not speculation of the Ko4+'s legitimacy off of another platform that uses the same engine that it will work as good our better on ours.
You do realize that if you could provide accurate, detailed information that this turbo does what everyone says it does you would have more Cobalt SS/TC and HHR SS owners asking for the K04+.
Well I look at it this way if a manifold was made to bolt on other popular turbo applications, then I could pick and chose of my own free will what turbocharger I want to run, not dictated by a vendors choice or pricing. Right now the vendors dictate what kits are out there for us because they have all the adapters needed.
mkriebs, I do appreciate what you and your shop is trying to do for the community, but you have to see my point about laying claims to saying something works on a application without factual proof.
I've been working with a new turbo company for the LNF on a similar set up to this. As soon as I'm done with all of the preliminary testing, I'll have a thread up with all of the information. As of now I've been on the dyno to receive base line numbers for the stock turbo with bolt-ons, I installed the turbo this past Saturday (5-30-10), and I'll be getting tuned for it this week (granted everything goes to plan) by Vince and dyno for results the end of this week or the following week (few variables in that). So far, so good on this turbo; I haven't had any problems at all Stay tuned!
P.S. Sorry to OP for any sort of thread jack... I'm hoping this will be the answer to what you and obviously others alike are looking for.
I'll have this all up for you guys really soon
Stay tuned!
No problem about your post, sounds like you guys are developing exactly what I'm after. I'm actually relieved you posted up something because I was ordering a turbo kit at the end of this week, now I'm gonna hold off and find out your results.
Originally Posted by Baron7700;4984121[B
]Im curious as to why you are so adamant that the same exact engine with a SLIGHTLY more restrictive airflow system would not apply to the same motor in an engine bay with better performance characteristics. Why would the kappa be any different then the delta?[/B]
I don't know what Werks has to do to there K04+ vs. BTF's. BTF's K04+ wheel upgrade is $825.00, Werks is $999.00, I would guess the difference is in the cost of the machine work as there is only one place to buy the bigger billet wheel for the K04+. All I was saying is if you want to prove the K04+ on a delta, get it on a delta platform and post some real world results. I offered to do it at a discount, as I would have been taking all the risk if it turned out terrible (it was not an unreasonable request). Nothing more, nothing less.
The problem with swapping the compressor wheel in the stock turbo is that the exhaust wheel is then mismatched. This is what causes the surge issues. When there is more overall pressure on the compressor wheel (figuring in boost and surface area) than there is on the exhaust wheel, then the turbo stops spooling and slows down very quickly. This is commonly known as compressor surge. If we could replace the exhaust wheel with a larger one, the issue would be resolved. However, the exhaust housing is cast in such a way, that it can not be machined for a larger exhaust wheel. This limits us to only making so much power, regardless of compressor wheel choice.
Are you the guy that Mallard from the Solstice forums is working with on your cobalt for a new bolt on turbo? If so I've been anxiously awaiting the results, I have that thread subscribed to over there
I'd take a true bolt on 375-400 whp turbo, its exactly what the community needs to fill the gap between stock and the turbo upgrade kits.
Because the 2 Cobalt ss/tc's that had the K04+ upgrade (although not the werks version according to mkriebs) ran like absolute ****, even with alot of tuning. I don't think either of them gained much over stock and I believe they even lost torque to boot. I just would prefer some real results on the delta platform, since we've seen 2 that had bad results.
I just got a user name on solstice and it wouldn't let me post up yet because I needed to wait for approval. But once I found this thread I figured I'd jump in. I'm working on getting the total results for this turbo to him as well as the entire LNF community asap. I'll keep everyone posted, and as stated before, I'll make a thread with all of the findings. But if I were you, I'd wait for this gem!
I am the guy that is working with Mallard
I just got a user name on solstice and it wouldn't let me post up yet because I needed to wait for approval. But once I found this thread I figured I'd jump in. I'm working on getting the total results for this turbo to him as well as the entire LNF community asap. I'll keep everyone posted, and as stated before, I'll make a thread with all of the findings. But if I were you, I'd wait for this gem!Oh I'm waiting man
In my opinion if he sells them for the price range he stated, and the turbo puts down 375-400whp with a tune, the new turbo upgrade is going to be flying off the shelves. I've said it a million times and numerous times in this thread alone that the community is starving for a true bolt on turbo charge with proven results in the 375-400whp range.
I had to wait to be approved to post up on the solstice forums also, think it took a couple of days.
Oh I'm waiting man
, I told him I would be the first to run it on my HHR SS if the testing results came back good. This is the first promising true bolt on since the talk of the K04+ (which was fail as far as cost to performance gains go). I'm glad he isn't trying to just rush this out to market as the next big thing but instead is taking the time to test it out before releasing it to the public.
Might I add to my statement...?
When you think about it, ramping up boost slower is hardly a bad thing. Yes, it 'feels' a bit slower off the line, but I can see it only helping the cause, especially in a front wheel drive car. To a minor point, ramping boost in slower will allow more traction to be had. Which, could very easily result in quicker times.
Well I contacted APR - High Performance Development for Audi, VW and Porsche Vehicles in Alabama about maybe doing something with our factory K04 turbocharger. They have been modifying the K04 successfully for some time. I offered my HHR SS to them or the turbocharger off my HHR SS to see what they could come up with.
Here's the response I got:
Paul,
In short, we simply don't work or modify any vehicles outside of the VAG product lineup. I am sorry we could not help you any further.
GO APR,Chris Gigon Sales Representative
Way to put the K04 on our vehicles GM, not even the aftermarket K04 tuners want to mess with it because it on a GM.
Sorry, just frustrated that no one has stepped up to make a true bolt on upgrade K04 for our cars. A upgraded compressor wheel for $825.00, isn't much of a upgrade for what you get.
Paul,
Dude , have you ever seen a TD04 Mandifold off of an SRt-4 , The turbine is actually stuck in the manifold **** eyed ... You think the K04 Balt design is bad , at least they gave us a K04 that bolts to a manifold and not something with a smaller trim like 75% of the other turbo 4's offered by every one else. We got it pretty good actually right now, with all the trans failures , I would be worried more about how you are going to run the power safely. This car is kind showing its weaknesses early so it kind of made me think twice about the big turbo setups. I personally would be better off just trading this in for a Z28 LS9 SC
Uh upgrade the trans if it fails. If you guys are unprepared to upgrade broken stuff then you should leave your car stock or GMS1, especially if its your DD. Not all of us have to worry about our LNF powered car being our DD, sure the warranty is nice, but gotta take responsibilty for it yourself if you go past GMS1.
Pay to play. I would just prefer a true bolt on turbo instead of having to switch out manifolds, or putting an adapter on, a new DP (or adapter again).
Anyone can build a V8, to me thats the easy way out, always has been. Then you can have the same fast car as every other joe blow does.
There's are a few out there, heck my GN from the 80's had bolt on turbo options, most VW's do, etc. I'm sure you can think of 2 off the top of your head without really trying. Bolt on turbo, injectors, re-tune and go. Hint: one of them was a joint venture of 2 big Automobile companies, made from 1990-1999.
