coolant temps?
Old Sep 5, 2008 | 10:46 PM
Bandit1's Avatar
coolant temps?
What's the highest you have managed to get so far?Purely a curious comparison question.I have seen mine as high as 205,but i dunno what that means since i dunno what the thermostat is set to kick in at...
*oops,posted wrong section,doh
Old Sep 5, 2008 | 10:48 PM
TruStinger's Avatar
Probably set at 205 or so. Alot of stock vehicles are somewhere in that neighborhood
Old Sep 5, 2008 | 10:50 PM
SSRedSC's Avatar
210. I think that the thermostat is open but the fan isnt running, Id be curious to know the exact temps. That was stuck in Washington in August for hours. I didnt know how high she might go so I just turned the heat and cooled it off.
Old Sep 5, 2008 | 11:25 PM
Bandit1's Avatar
Thanks,ya,i guess i did post this in the right section,but thought it more a general question..
Ok..if it's a 205 stat,i feel good.I was just wondering as it has been bakin hot here.Also,i am wondering how loud the fan is on these balts?I have'nt heard mine while driving(like,at a stop,even).On my previous ride,it was obvious when it ws kickin in...
Oh,and i just wanted to say that since i am still in the break in period,i have been following the guidelines,so this is just from some quick spurts to 5k in 95 weather and high humidty.I know some of you may be running it harder,but it gives me a good feel for where i should be depending...
Old Sep 6, 2008 | 12:12 AM
marcusicp's Avatar
I have seen 219 a few times.
Old Sep 6, 2008 | 12:19 AM
blackss2.0's Avatar
210*
Old Sep 6, 2008 | 12:41 AM
Zander916's Avatar
199 is the highest for me so far
I think engines make higher power with lower temps (not much) and better emissions with higher temps... ? Someone correct me if I'm wrong.
Old Sep 6, 2008 | 12:07 PM
krispy's Avatar
Higher engine temps tend to make N/A cars go slower due to the heating of the incoming air, when you really dig into it, its not that simple. I can't find what I'm looking for, but back when I was in Formula SAE people were looking at heat rejection vs. power output to find the optimal coolant temp. There was a point where going too low caused lower power.
There are other considerations besides emissions and power though. At lower coolant/engine temps the oil doesn't get as hot and the condensation and acids that build up in the oil don't get evaporated as quickly. I tend to leave coolant temps alone on a car as a result of this since I care more about longevity than a 1-2 hp gain.
Old Sep 6, 2008 | 12:20 PM
MapOfTaziFoSho's Avatar
205
But it got down to 195-199 quickly.
Old Sep 6, 2008 | 12:26 PM
Darkmanx's Avatar
my fan turns on early and im always at 175.
Old Sep 6, 2008 | 12:31 PM
slowstang's Avatar
Mine hovers inbetween 194-199 all the time.
Old Sep 8, 2008 | 11:53 AM
IsItFast?'s Avatar
I would take that in to the dealer - it should not run that cool! There is something wrong there.
I would bet money on the t-stat being 195 degree. Highest ive seen is 210ish, but usually hovers right around 190-200, which would indicate a 195 degree t-stat.
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
