Custom Charge pipe ahoy!!!! help with code
Well, I menage to get someone to do a custom charge pipe kit. as of now the hot side is done and currently working on the cold side (waiting for next paycheck so I can afford it) The car did gave a code: P0299 anyone knows what that is? Here are some picks of the job so far and remember, this is still a work in progress!!! BTW I would post vidoe but currently dont have a video camera
http://www.chevyhhr.net/forums/showthread.php?t=25240
piping looks nice I was going to get one of my friends to do this for you guys a while ago but i lost touch with him
looks like a combo of the performance and standard charge piping
P0299 is an underboost code. What did you do to the stock bov? Did you add a delete plate?
If you just unhooked the vacuum line to the stock bov then its opening under boost and leaking. If you connect both then you should be fine until you get a delete plate, just remember to leave the spring/diaphragm inside since its what actually seals the passages.
Although i wonder if you'll have enough vacuum to open both bov's, it would be best to connect the bov directly to the intake manifold and bypass that solenoid its connected to.
avisame cuando la termines para que hagan la mia. Me pintaron el Blowoff negro y bronce
se ve jummm
se ve jummm
Looks like Injen without the badge. Good job on wasting money!
1. Injen uses 3 90 degrees bends, mine uses only 2
2. My home made kit includes a sequential BOV valve that sounds amazing btw (will post video when I get my hands on a video camera with decent sound)
3. Like BartSS just said previously, mine does not go over the valve cover, witch I think in my humble opinion that the valve cover would transfer unwanted heat to the pipe.
4. I use Tbot Clamps
5.I make sure that every time I open my hood, people will see something that have not seen before witch appeals to me a lot
know that my hot side cost me 280USD but this includes the BOV that Injen does not have. the lowest cost I found for Injen was 210USD + shipping witch takes the kit to 250USD. Would you pay 30 bucks for a Sequential BOV installed already in your hot side kit? I know I would!!
That pipe has more bends and more severe than the injen lol and the heat is worse at the back of the engine than the valve cover. Most of the heat is from the boost anyway. I really like the injen hotpipe it's there cai that had issues. The heat disappears when you run a better flowing intercooler also.
