Custom Charge pipe ahoy!!!! help with code
Old Dec 10, 2009 | 04:49 PM
Balento18's Avatar
Arrow Custom Charge pipe ahoy!!!! help with code
Well, I menage to get someone to do a custom charge pipe kit. as of now the hot side is done and currently working on the cold side (waiting for next paycheck so I can afford it) The car did gave a code: P0299 anyone knows what that is? Here are some picks of the job so far and remember, this is still a work in progress!!! BTW I would post vidoe but currently dont have a video camera
Old Dec 10, 2009 | 04:53 PM
elecblue06's Avatar
http://www.chevyhhr.net/forums/showthread.php?t=25240
piping looks nice I was going to get one of my friends to do this for you guys a while ago but i lost touch with him
looks like a combo of the performance and standard charge piping
HB_SS/TC's Avatar
P0299 Turbo/Super Charger Underboost
Old Dec 10, 2009 | 04:54 PM
cmiller8006's Avatar
turbocharger underboost. just had it last week, cranked the boost up and all is good. dont know what caused it.
Old Dec 10, 2009 | 04:55 PM
peachpuff's Avatar
P0299 is an underboost code. What did you do to the stock bov? Did you add a delete plate?
Old Dec 10, 2009 | 04:58 PM
Gabi's Avatar
se ve supeeeeeer bien mano!!!!!
congrats!!!!
ya hicistes tuberia o todavia??
so far so good!!!
saludos
Old Dec 10, 2009 | 05:50 PM
Balento18's Avatar
mmmm..... now that you mention it, no stock BOV still in place. Could I be leaking boost out of the stock BOV? in that case could connecting both at the same time would work until I get to do a stock BOV delete?
Old Dec 10, 2009 | 06:56 PM
peachpuff's Avatar
If you just unhooked the vacuum line to the stock bov then its opening under boost and leaking. If you connect both then you should be fine until you get a delete plate, just remember to leave the spring/diaphragm inside since its what actually seals the passages.
Although i wonder if you'll have enough vacuum to open both bov's, it would be best to connect the bov directly to the intake manifold and bypass that solenoid its connected to.
Old Dec 12, 2009 | 10:38 PM
SaleenFreak's Avatar
avisame cuando la termines para que hagan la mia. Me pintaron el Blowoff negro y bronce
se ve jummm
Old Dec 12, 2009 | 10:57 PM
austinss's Avatar
^^wtf?
Old Dec 12, 2009 | 11:02 PM
recklessnova's Avatar
tell me when you finish your so they can do mine I just painted my blow off black and bronze
Translation of whats about the wtf
Josh
Old Dec 13, 2009 | 12:07 AM
Billsac's Avatar
Looks like Injen without the badge. Good job on wasting money!
Old Dec 13, 2009 | 03:03 AM
BartSS's Avatar
Wrong because the Injen goes over the valvecover
Old Dec 13, 2009 | 03:23 AM
elecblue06's Avatar
not to mention money was probably saved doing it this way
Old Dec 13, 2009 | 10:33 AM
Balento18's Avatar
se ve jummm
Will do, I will finish the cold side this week along with the downpipe. I will post picture of those as I finish them.
Note the following:
1. Injen uses 3 90 degrees bends, mine uses only 2
2. My home made kit includes a sequential BOV valve that sounds amazing btw (will post video when I get my hands on a video camera with decent sound)
3. Like BartSS just said previously, mine does not go over the valve cover, witch I think in my humble opinion that the valve cover would transfer unwanted heat to the pipe.
4. I use Tbot Clamps
5.I make sure that every time I open my hood, people will see something that have not seen before witch appeals to me a lot
know that my hot side cost me 280USD but this includes the BOV that Injen does not have. the lowest cost I found for Injen was 210USD + shipping witch takes the kit to 250USD. Would you pay 30 bucks for a Sequential BOV installed already in your hot side kit? I know I would!!
Old Dec 13, 2009 | 11:57 AM
TCguy's Avatar
I ended up taking off my Injen pipes, didnt like the way they went right over the motor like that and seemed like they got way hotter then the plastic themsleves.
Old Dec 15, 2009 | 03:00 AM
IsItFast?'s Avatar
so when you do the cold side, you are going to relocate the MAF and tune for the change? Otherwise that blow off valve is going to cause you trouble, you will be venting metered air...
Old Dec 15, 2009 | 03:09 AM
berto's Avatar
the code might be caused by low boost
maybe because of the HKS bov...just throwing it out there
Old Dec 15, 2009 | 12:51 PM
jarhead's Avatar
That pipe has more bends and more severe than the injen lol and the heat is worse at the back of the engine than the valve cover. Most of the heat is from the boost anyway. I really like the injen hotpipe it's there cai that had issues. The heat disappears when you run a better flowing intercooler also.
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
