dashdaq cobalt theme
Old Jun 13, 2009 | 12:06 AM
tomj77's Avatar
who is the guy who made the cobalt theme for the dashdaq? cant find the post, need it. help
Old Jun 13, 2009 | 12:02 PM
Nakaiya21's Avatar
you mean girl....that would be me... pm me your e-mail and I will send you the skin....
Old Jun 13, 2009 | 12:07 PM
40rty's Avatar
You made a theme? I have been on the DashDaq forums. DOes your theme have a splash screen like the RPD. I have a guy that is going to be working on that right so we can have the same one. Can you send me an email? Thanks
Old Jun 13, 2009 | 12:23 PM
Nakaiya21's Avatar
https://www.cobaltss.net/forums/show...hlight=DashDAQ
Here is the thread... the examples of the skin are on page one.... Keep in mind that the pictures aren't the highest quality... I have no problems e-mailing the skin...
I need e-mail addresses though
Old Jun 13, 2009 | 12:36 PM
40rty's Avatar
40rty07@gmail.com
Old Jun 13, 2009 | 12:42 PM
Nakaiya21's Avatar
^^ sent... I simply sent the .ddskin file which is all you need for the install... If you need anything else from the theme, let me know and I will try to find and send...
Btw...for anyone else interested... this theme is my sport tint red theme (for my car)... basically sport tint red, black, and silver... You can modify the theme to match your own theme... doing so will require the gauges I used and GIMP... I can send whatever but it may take a little while to dig up....
Old Jun 13, 2009 | 05:30 PM
40rty's Avatar
^^^^ Thank you so much. Great person!!!!!! A++++ helped me setup my DashDaq like I wanted. Once again thank you for the theme and helping figure out the features.
Old Jun 13, 2009 | 06:17 PM
tomj77's Avatar
i installed a splash screen and now my dashdaq goes black on boot and doesnt work, guess im redoing it damit
Old Jun 13, 2009 | 07:33 PM
Nakaiya21's Avatar
try a re-flash... simply step trough your software re-flash cd and hopefully your issue will work itself out... I have never heard/seen anything like that before so I am not sure I could help...
Old Jun 13, 2009 | 08:05 PM
tomj77's Avatar
i just did a clear user settings, worked good, just had to redo everything
Old Jun 13, 2009 | 09:55 PM
Nakaiya21's Avatar
been there, done that... if you need any help setting up the theme, let me know... Keep in mind that for the analog gauges there are digital readouts that are below the labels... you will not be able to see them, but if you press below the label you will be able to program them...
No problem... if you need anything else, let me know... I will look into that performance question when I get the chance and if I find anything I will pm you...
Old Jun 14, 2009 | 12:27 AM
tomj77's Avatar
i was hoping it would have the 9 box and the 1 analog gauge and 6 digital, 3 on either side, i probably wont use it cause i cant get enough on one screen with it
Old Jun 14, 2009 | 02:00 PM
Nakaiya21's Avatar
Well I can see about getting something mocked up by next weekend if you really want it... however, the reason while there are limited inputs is because you really can't monitor that much information (too distracting). It also makes the screen pretty busy...
Old Jun 14, 2009 | 04:53 PM
tomj77's Avatar
i can, just put warning sounds for all of them. even if i dont monitor them i still like the look. i like the six boxed one on the night theme, the numbers are quite big and easy to see. and if u can can u make the background black instead of a background pic, its much easier on the eyes at night and less distracting. i want a nice one for night time
Old Jun 14, 2009 | 05:47 PM
Nakaiya21's Avatar
if you go to the dashDAQ website then you will find a plain black background that you can incorporate... You can also build one in gimp... If you change the background for one, it will change it for them all (at that point you are looking at a new skin)... I have decided to update the theme and I will keep your ideas in mind when I build it...
If anyone has any other ideas, let me know and I will try to incorporate them...
Superslowbaltt
Sep 22, 2015 10:24 AM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
Bluelightning
Sep 8, 2015 05:18 PM
jthwjde
Sep 7, 2015 09:24 AM
