Dejon Intake?????
Old Feb 23, 2009 | 02:11 AM
  #76
Grich171's Avatar
jus ordered mine couple of days ago ill prolly end up doing what you did with that hose..howd u get it to stay in the steel braided line?
Old Feb 23, 2009 | 02:17 AM
  #77
HB_SS/TC's Avatar
I bought something that looked like this and ground it down until the braided part clipped into place.
Old Feb 23, 2009 | 08:34 AM
  #78
boostking's Avatar
I did the test on this intake for dejon. I never had a problem with the intake. but I believe the reason the stock tube is fixing the problem is because there is a one way check valve in there. its not how the maf is sitting. look at the facotry intake, its in the same spot.
for the tuning problem, first the tuner needs to make sure that factory wide band is warmed up and moving around. I was seeing some funny numbers when tuning because its was not warmed up. (I had to run the car around 3k for 3-4min between each change to get it up to temp.
Maf tuning is def. needed to smooth out the a/f. those dyno pics are with smoothing on for the a/f. if you look at it normal I am sure its all over the place. MAF TUNING IS NEEDED FOR A PERFECT A/F through the rpm range.
hope this helps.
Old Feb 23, 2009 | 09:17 AM
  #79
40rty's Avatar
Hey, is the SRI that Clear Image made piping go all the way to the turbo and Mandrel bent? Or are the still using half of the stock piping? If so I might just order a SRI as well from them and compared the 2.
BTW " This Sex is on Fire" woooooooot!!!!!!!!!!!!!
Old Feb 23, 2009 | 09:46 AM
  #80
eiuprtycntrl's Avatar
they are still designing theirs. They also had this problem where the boost is all messed up and they are making an intake that is actually correct and will not have these problems. This is why I am waiting on theirs.
Old Feb 23, 2009 | 11:28 AM
  #81
Terminator2's Avatar
Originally Posted by Cobaltss/TC
i just hear axles snaping and clutches slipping when i hear no lift shift with my mods
X2. I always lift to shift if I do not I get no traction at all in the next gear unless it is from 3rd to 4th.
Old Feb 23, 2009 | 11:31 AM
  #82
Cobaltss/TC's Avatar
SO far the SRI will use half of the stock piping that is connected to the turbo, the full intake goes into the fender fully mandrel bent then goes into a coupler that connects to the turbo, they have pics up on their website
Old Feb 23, 2009 | 11:45 AM
  #83
steddy2112's Avatar
Originally Posted by ericgt79
you cant have proof read that **** before you hit submit, you just couldnt have
Did I ******* stutter?
Larger element, not the 'cooler' air.
When you're moving everything is cooler... go on, believe that intakes are teh leet mod.
QFT.
I NLS on the 2-3 and up, but the 1-2...
**** I can't go WOT really in 2nd, but do.
Last edited by steddy2112; Feb 23, 2009 at 11:45 AM. Reason: Automerged Doublepost
Old Feb 23, 2009 | 11:51 AM
  #84
QFT.
2-3 Spins pretty bad for a few seconds especially if the asphalt is cold.
Old Feb 23, 2009 | 11:58 AM
  #85
XxCOBALT_TURBOxX's Avatar
Originally Posted by HB_SS/TC
Here is what I did. Temporary fix
LOL OMG UR A LIFE SAVER!!! I WAS TRIPIN OUT ON HOW I WAS GOING TO FIX THIS AND IF IT WAS MESSIN UP MY CAR ......WHAT DID U USE TO CONECT THE TWO HOSES? AND WHERE DID U GET IT? AND WHAT SIZE IS IT?? THANXZ A LOT FOR THE HELP
Old Feb 23, 2009 | 12:27 PM
  #86
I believe it is called an emissions hose and you can find it the the help section of your local autoparts store.
Guys,
I posted this same problem about 2 weeks ago. I called Pychosteve and he confirmed that it was that VAC line. I'm actually sending my intake back to dejon to get my flange welded on and repowdered coated because of this problem. Call Dave up and ask him to see what he can do for you. That's what I did.
X2 this man and I speak the truth it is the vac line. The intake works fine no codes or anything but you really need a good MAF tune after you install any intake it will skew the reading and cause the A/F to change some. that is why I am geting mine tune touched up next month to make sure, and the money I saved will pay for the tuning touch up so win win.
Last edited by Terminator2; Feb 23, 2009 at 12:37 PM. Reason: Automerged Doublepost
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
OrangeCoba
Sep 25, 2015 06:06 PM
