Direct bolt-on turbo (ko4 replacement)
Old Dec 20, 2012 | 08:08 PM
  #851
Fastgti69's Avatar
Originally Posted by Terminator2
FF-ace has a 5857 on his car with a ZZP header and it made only 430 whp and only 360 wrtq on 24 psi on E-47 and meth. He has a MBC so the only control I have is timing PE and cams no boost control on my end. I was disappointed but if he cranks it up to 33 psi he should see well over 500 whp. It spools 400-500 RPMs slower than I thought it would as well.
I believe it. I mean the stock fuel system has it's limits with ethanol. I experienced it myself with my EFR. It looks like it's repetitive with the 410-430 whp dyno results with the turbos. You even have meth to aid the turbo a little. At this point no matter how big the turbo is you will need an aid in fuel to support 500whp+ on E or other fuels. Cams/ fuel lobe or another injector seems to be the case. Correct me if I'm wrong please.
Old Dec 20, 2012 | 09:17 PM
  #852
strazdice's Avatar
Another fuel injector is a poor fueling solution, we need a BEETER FUEL PUMP made! ZZP??? When are ya gunna make one! Or any vendor that can make a direct replacement??? The lobe only does so much, they're great to increase some power, but it is and will always be the fuel pump.
Old Dec 20, 2012 | 11:04 PM
  #853
SSlobalt's Avatar
It's a mechanical fuel pump, fit within a certain size restriction. It would need a bigger piston to pump more fuel but there isn't enough space for a bigger piston. What ZZP did was increase the stroke, maybe beyond even what it was intended for, but that's all that can be done without some serious fabrication and modification to existing fuel lines.
Old Dec 20, 2012 | 11:12 PM
  #854
40rty's Avatar
I'm curious to see what fuel pump the corvette will have.
Old Dec 21, 2012 | 01:08 AM
  #855
T-Man's Avatar
A better fuel pump is quite the R&D and the materials involved/required would be pretty expensive.
It's more or less a gamble much like their ZFR was. You know how it goes around here; plenty of people to rabble rouse and say they're going to be on board to buy it and then turn around and back out due to lack of funds.
Would be really cool if they were to come up with another pump like CP-e did for the MS3/6 DISI.
Old Dec 21, 2012 | 01:20 AM
  #856
strazdice's Avatar
Ya same here, also curious to see if they make a better fuel pump for the cruze ss (which i doubt) but that new srt-4 with 300/300 will be tough to compete with, if it actually does get released as with the cruze ss
Old Dec 21, 2012 | 01:23 AM
  #857
strazdice's Avatar
Ya i hear ya on that, my friend got an upgraded pump on his ms3 runs way better plus more psi of course
Old Dec 21, 2012 | 01:32 AM
  #858
strazdice's Avatar
Ok so, a bigger fuel line doesnt seems to be to hard, right i kno they increased the "cycle" of the pump to enlongate it, to thus put more fuel in, why does everyother car that ppl want to modify have a pump?? My friend and his ms3 does and thats DI. I understand the fab work isnt exactly easy by any means, but a new case to hold a bigger piston i wouldnt think would cost more than $500-700 max would to sell back to us as a possible kit. Would it?
Old Dec 21, 2012 | 07:56 AM
  #859
Omnigear's Avatar
Cant do bigger due to design of the pump.mote like it is not financialy smart
Old Dec 21, 2012 | 09:03 AM
  #860
Terminator2's Avatar
He still has fueling room on his car. Turbo just seems to make weak torque for the boost levels, timing, etc being run and the thing spools at about 4400 which seemed a bit late as I expected it to spool at 4000. I tried everything to make it spool sooner and no change no matter what timing (cam and ignition) and PE I ran it stayed the same or got more laggy.
Old Dec 21, 2012 | 09:09 AM
  #861
Unfortunately, likely one way too big to bolt up to the LNF's head and even if it did the issue becomes can the little 2.0 make it build fuel pressure properly as the displacement of the pump could be 2-3 times that of a stock LNF pump so its piston will likely be a lot larger and its stroke a lot longer as well.
Old Dec 31, 2012 | 06:40 PM
  #862
Team SS's Avatar
TTR Powered
About to put my BNR2871 Revised turbo up for sale guys..
Old Jan 1, 2013 | 01:50 AM
  #863
AARON-SS-TC's Avatar
shoot me a price if its cheaper than a new s20g.
whats wrong with it, and how many miles?
what are you getting to replace it?
Old Jan 1, 2013 | 02:16 AM
  #864
kdub1492's Avatar
price is gonna be $1k plus shipping. it is brand new, so no problems with it. Great turbo, but he upgraded to a t06 turbo i believe
Old Jan 1, 2013 | 02:33 AM
  #865
Frogstofall's Avatar
Old Jan 1, 2013 | 10:24 AM
  #866
lol...^^^
$1000 for a NEW revised BNR is a good deal.
i should have the extra money here in the next week or 2, so i am getting a turbo and a new clutch
Old Jan 1, 2013 | 11:59 AM
  #867
lol...^^^
I was under the impression it has been driven on? Can you clarify Richard? Also would like to see some proof that it makes and holds 30psi. A screen shot from a log maybe?
Old Jan 1, 2013 | 09:51 PM
  #868
true....
Old Jan 1, 2013 | 10:40 PM
  #869
Team SS's Avatar
TTR Powered
The BNR2871 was taken to Bryan at BNR to have all new wheels, bearings, shaft installed.
The asking price is only $800 + shipping.
Also, the BNR is able to hold 30psi, but not on pump gas for very long. 28psi is the max that the BNR2871 Revised can handle for what i've put it thru.
The new One i'm running is a TD06 Custom Built By BNR for me (Buddys with owner)
Old Jan 1, 2013 | 10:49 PM
  #870
Team SS's Avatar
TTR Powered
I was gonna be 100% brand new, til bryan told me tonight that he didnt replace the housings. just all the wheels and such.. still like new i guess
Old Jan 1, 2013 | 10:56 PM
  #871
kdub1492's Avatar
Oh okay, I remember seeing it on Facebook, and you hadn't posted yet so I figured I would help you out haha
Old Jan 1, 2013 | 11:03 PM
  #872
Team SS's Avatar
TTR Powered
haha thanks man, I was gonna post up a FST this weekend. I've only got 3 days left til my Paid vacation starts so lol. i'll need something to do for that week
Old Jan 1, 2013 | 11:04 PM
  #873
kdub1492's Avatar
haha yea, heading to James to get the new setup tuned and everything? Should be a good time!
Old Jan 1, 2013 | 11:08 PM
  #874
damn good price...doubt ill have the money in time though. that thing will probably be sold by tonight, or by the weekend at latest...
Old Jan 1, 2013 | 11:10 PM
  #875
Team SS's Avatar
TTR Powered
I don't think it will sell that fast lol.
And yeah, its a damn steal IMO.
kdub1492 haha yea, heading to James to get the new setup tuned and everything? Should be a good time!
I mite need new tires by the time i get back
Not only are we tuning for the new custom turbo, but also for the custom meth kit Snow Performance made for me
