Direct bolt-on turbo (ko4 replacement)
I don't think I shared this here. We had a little meet last month. I was the camera car. Please ignore my very consistent stupidity.
Southeast WI / Northeast IL Ecotec Meet - YouTube (can't watch on your phone unless you use the browser method)
Actually Antone your car has no boost ramp. Boost comes in when turbo full spools. Bnrs don't full spool quick, But his peak tq is at 5200 which is much better then 4500 and dropping off. Perks of ethanol.
So where's is this graph for 441 because it's no where to be found!
QUOTE=elecblue06;6599776]drewbroo
398/436 was my best on the mustang dyno on E30. (25 PSI) On the dynojet and 50/50 mix, 441/488 @ 27.5 PSI.
The car is now sold and detuned for 91 OCT @ 24 PSI for a female driver.
K&N SRI, CIA CP's, ZZP IC, Synapse Catless DP, GMS1 sensors, 3'' Catback, BNR2871 E47 blend 18 degrees max timing 393WHP
and hhrsouth put had numbers around the 380 if I remember correctly on 91[/QUOTE]
With all the fucked up transmissions happening to people who are turbo swapped, think ill stick with the K04 lol. I really wanted the BNR too but I dont have the garage/time to be swapping trannies out
Lol. Thanks.
-edit-
nice meshuggah outro. hahah. WIN!
What we need to do is hit up shepard trans and see if they are willing to build us a trans. I remember there was a thread about this and we needed ten people to buy in but it fell through
Isn't ZZP's Transmission (Stage 1 I believe) Strong enough to handle more power?
ZZP Tranny
This is a cheaper solution than having someone develop one I would assume
Isnt there a guy on here that blew his zzp trans? And zzp dosnt have the f35 trans available right now. Shep trans is charging 1650 for a billet 3,4 gear which is our issue. The extra 250 if you ship it to them and the install the new gears... So your still under 2k idk how much shipping would be can't be that much
