Direct bolt-on turbo (ko4 replacement)
Old Oct 3, 2013 | 07:54 AM
  #1726
09CobaltSS1's Avatar
I haven't heard anything besides slower spool and has the capability of more power output. I think with pump gas I could net 425whp. On the ZFR I think 400 is hard to net with just pump gas? I wanna avoid E85 if I can for the same power output. I don't know what I wanna do...
You do realize that the zfr and wr-3 are both efr6758's right? Granted I don't know the turbine wheel specs for the wr-3 but I would have to think they are both pretty similar.
Old Oct 3, 2013 | 08:41 AM
  #1727
Wert842's Avatar
Originally Posted by 09CobaltSS1
I'd just hate to see you take the "normal" progression that most of the folks in this platform seems to be plagued with.
Install a midsized turbo,
get addicted to the power,
crave MORE power,
invest a bunch of time and money in a big boy turbo setup,
gets frustrated with the results and work involved,
sell car or.... go back to smaller midsized turbo
Like you said to Payam.... stick with what you know works man.
Unless you're willing to really go the distance with it that is.
I know I know. I say I'll go bigger but I really can't justify it. I think really that whatever I'm at now is almost too much from time to time. Like anything over this would be overkill and the power would be completely useless. I'm just gonna stick it out and ride with the zfr!
You'll be able to make 400 on 93 with a ZFR. Guarantee Sam is if he would get the thing on a dyno already!
Hey hey. Don't be yelling at me. I'm lazy. Haha.
At least I have a bigger turbo.
Originally Posted by Fastgti69
LOL Almost! You are sounding like me though. Remember, if the turbo comes out why not go bigger? hahaha. I wish my balt was somewhat close to what it's supposed to do.
Hahaha. How about it. I do remember telling you that...
Sent from my Samsung Galaxy S4 using CobaltSS
Old Oct 3, 2013 | 08:56 AM
  #1728
Terminator2's Avatar
Can I attain 425whp on the ZFR though with 93?
Maybe but you are looking at 29-30 psi and a big torque shock to your trans at 3800-4000. Sams trans did not last long at 27-28 psi with the zfr on 93.
Old Oct 3, 2013 | 10:33 AM
  #1729
taintedred07's Avatar
Well yea if you're going wot all the time
Old Oct 3, 2013 | 11:17 AM
  #1730
Fastgti69's Avatar
29 psi 100 octane, do it. That video of ZZP with 3rd gear just going from 60-100.. Yea that's what it will do.
  #1731
Wert842's Avatar
Ya I definitely beat my old trans to death. I'm surprise it lasted that long. Only like 3-4k mikes with the zfr and it was done for.
Old Oct 3, 2013 | 11:31 AM
  #1732
I wonder what psi ect it would take to hit 500whp on the zfr with the following mods:
Fueling: bigger injectors, cams/lobe, (5th injector needed?)
Motor: stock block, zzp rods, wiseco pistons, arp head studs, ect
Area47 tuned full e85
Old Oct 3, 2013 | 11:47 AM
  #1733
Fastgti69's Avatar
I wouldn't do full e85. I don't think you can hit 500whp+ on that gas. 35 psi I'm gonna guess LOL
Old Oct 3, 2013 | 12:01 PM
  #1734
Omiotek's Avatar
the most you will hit with a 6758 is 500 crank and . 500whp 40lbs a boost probablly if not more
Old Oct 3, 2013 | 12:16 PM
  #1735
Really? 40lbs holy crap, I was thinking 30lbs would be close to high 400s
Old Oct 3, 2013 | 12:21 PM
  #1736
Yes full e-85 will require a 5th injector at that power level.
  #1737
Zzps zfr dyno graphs show they hit 515whp with 28.8lbs and 540whp with 35.2lbs, although that might be with the 2.1lnf.
Old Oct 3, 2013 | 12:36 PM
  #1738
Meh depending on the fueling, I sort of disagree. On e35 at 25.5psi I hit 421whp with a 6758 which is just shy of 500bhp factoring in a 15% drivetrain loss.
Full e85? **** man, I need a 5th injector now to safely go past 25psi and that's an e35 blend. Never mind straight e85! Upgraded can lobe and 5th injector would probably be an absolute must with that sort of fuel demand at that power level.
Old Oct 3, 2013 | 12:37 PM
  #1739
And no one has come even close those numbers with a zfr. Zzps dyno reads high.
Old Oct 3, 2013 | 12:46 PM
  #1740
Well I've been running cams with the upgraded fuel lobe for a couple months now on full e, but going to put the bigger lnf injectors and a 5th injector in also most likely.
Old Oct 3, 2013 | 12:48 PM
  #1741
True, but I don't think many people have pushed a zfr to 35lbs with the same mods and fueling
Old Oct 3, 2013 | 01:04 PM
  #1742
10% driveline loss is more like it :p
Old Oct 3, 2013 | 01:12 PM
  #1743
515 whp at 29 psi is still a lot higher than anyone has made with a zfr.
Old Oct 3, 2013 | 01:13 PM
  #1744
kdub1492's Avatar
I think people look at my wr3 graph and forget it's not a 6758, it was a custom letup with PTE Which was planned to be released then things happened which stopped that from happening. Pwerks then switched to using an efr system. Mine is a little bit bigger then the 6758, and spools slower. Although I don't mind cuz I'm really not hammering down hoping to get full spool by 4k anyways haha
Old Oct 3, 2013 | 03:28 PM
  #1745
shroogis's Avatar
I wouldn't be so sure. A GMS1 car made 264whp on ZZP's dyno. Don't go spreading false information.
Their 'lofty numbered' ZFR car trapped 136mph, much higher than anyone elses ZFR; thus the 500+ doesn't seem out of line.
Old Oct 3, 2013 | 04:09 PM
  #1746
Sorry but their mustang dyno reads high. GMS1 on a properly calibrated mustang dyno is around 230 whp.
Old Oct 3, 2013 | 04:11 PM
  #1747
Omiotek's Avatar
that was an over exaggeration. at 25psi on 93 with hp tuners old beta i made 416whp at 25psi at 6500 with a whole lot of room to grow and make more if i wanted to supply more fuel and boost.
Old Oct 3, 2013 | 04:36 PM
  #1748
Shortbus's Avatar
That car is damn fast if it trapped 136 on a zfr.
Old Oct 3, 2013 | 05:15 PM
  #1749
soundjunky's Avatar
lurker chiming in here;
I thought that a properly calibrated dyno was registering a little over 230whp for stock SS/TC's??
Old Oct 3, 2013 | 05:24 PM
  #1750
I always thought it was 240whp.
