Direct bolt-on turbo (ko4 replacement)
Old Sep 6, 2013 | 02:52 PM
  #1476
ATLsilverSS's Avatar
Originally Posted by kdub1492
Car goes under the knife Monday for 5th injector, cams and retune
What size injector you gonna use?
Old Sep 6, 2013 | 02:56 PM
  #1477
kdub1492's Avatar
Whatever is a part of their kit. Not sure of the size.
Old Sep 6, 2013 | 03:03 PM
  #1478
Fastgti69's Avatar
Why not say **** the 5th and get the real 4.
Old Sep 6, 2013 | 03:08 PM
  #1479
kdub1492's Avatar
You talking about the 4 that ZZP offer now? I'm skeptical about them as of right now. And I don't think those alone would allow for me to use E anyways. I think regardless of the route I go I will need the 5th setup. We will see though. The Pwerks 5th injector is not like the ZZP, they actually tap into the manifold and weld a bung in for the injector
Old Sep 6, 2013 | 08:54 PM
  #1480
Fastgti69's Avatar
Not a problem, I know what you mean. I would like to see someone get it and try it out before going into them. Interested in your results.
Old Sep 6, 2013 | 09:47 PM
  #1481
kdub1492's Avatar
Yea I do want to see the difference in the same tune with the different injectors, especialy the big turbo guys like us
Old Sep 7, 2013 | 11:05 AM
  #1482
AARON-SS-TC's Avatar
I wonder if the upgraded injectors would make a difference at all on a stock turbo???
Old Sep 7, 2013 | 12:27 PM
  #1483
Omiotek's Avatar
its not needed on the stock turbo at all....you can just squeeze by on e85 with the stock ones on the stock turbo its when you go bigger you need the fuel.....
Old Sep 9, 2013 | 08:57 PM
  #1484
ae_xiong's Avatar
Originally Posted by Wert842
No, I really didn't NLS other than when I was at the track. It shattered third from doing waaayyyy tooo many third gear pulls. It was just a matter of time though. It held up strong with the zfr for the time it was in there. Zfr hasn't really caused me any problems. I'm actually getting the same MPGs as with stock turbo if not more.
Nice, that's good to hear. So what track times were u able to pull off with the bigger turbo? Also, how long was the stock tranny able to hold up on the bigger turbo? I'm sure you upgraded your clutch too right?
Old Sep 9, 2013 | 09:33 PM
  #1485
HAHN S20G turbo, $1079 shipped, get them while they are hot....lol
Old Sep 9, 2013 | 09:44 PM
  #1486
Wert842's Avatar
There's a ton of wheel spinning going on and it doesn't allow me to get super good times but I've managed a 12.89 @116 on street tires and some traps of 119-120. Its capable of low 12s-high 11s with slicks. Stock trans held up for about 6k miles with the turbo and Ky stage 3 clutch. I also beat my car, but I do maintain it pretty good and check everything regularly.
Sent from my Samsung Galaxy S4 using CobaltSS
Old Sep 9, 2013 | 11:22 PM
  #1487
Fastgti69's Avatar
Nice 120 traps is what I wanted to hear. When people asked me what my car would trap with the ZFR I said something liek 120-122 with my e47 tune.
Old Sep 10, 2013 | 11:20 AM
  #1488
Wert842's Avatar
I'm still on 93. I only hit those high of traps when I rev'd to 7300 in second and third and then NLS 3-4. Not gonna lie though, when you NLS there the power is incredible. It just keeps flowing so smooth. Its almost way too good. Somewhat addicting...
Old Sep 10, 2013 | 05:14 PM
  #1489
Fastgti69's Avatar
I have no power LOL, at least nothing like yours.
Old Sep 11, 2013 | 02:27 PM
  #1490
ae_xiong's Avatar
Nice! That's really good for street tires. Wait, what kind of street tires are you running with anyway? Cuz I have basic bolt-ons with tune(23psi) only and I'm still spinning in 2nd. LOL I have Nexen 300 ultra-high performance summer tires. I want something better. Thinking of DR's but not sure if it's a good idea with winter coming up. LOL
Old Sep 11, 2013 | 02:31 PM
  #1491
ae_xiong's Avatar
That's why our t/c balts are so fast. They don't have to deal with the turbo lag again when we shift compared to other t/c cars. NLS FTW! However, I usually onlt use NLS when it's a pretty close race. LOL No need to stress anything out if I don't need to.
Old Sep 11, 2013 | 02:46 PM
  #1492
Shortbus's Avatar
Don't bother with dr's, get some 17" redline wheels with a slick. At the track I NLS all gears usually, only really use at the track.
Old Sep 12, 2013 | 01:56 PM
  #1493
ae_xiong's Avatar
That's probably why you're able to hit 13.3 with only a tune and drop in filter. Speaking of which, were you on slicks too when you made that pass?
Old Sep 12, 2013 | 02:13 PM
  #1494
Shortbus's Avatar
Stock tires, 93octane, tune, drop in filter.
Old Sep 12, 2013 | 08:44 PM
  #1495
Wert842's Avatar
Definitely had to have a good day then. Negative DA at least.
Old Sep 12, 2013 | 09:28 PM
  #1496
Shortbus's Avatar
It was around 6pm I believe, sunny and around 85+ degrees out.
Old Sep 12, 2013 | 09:40 PM
  #1497
Wert842's Avatar
Pretty damn good then.
Old Sep 12, 2013 | 09:41 PM
  #1498
Shortbus's Avatar
DA that day was 1,300 feet, and RD was 96.25.
Old Sep 13, 2013 | 12:07 AM
  #1499
ae_xiong's Avatar
Nice day = good run. Good run = good track times. Good track times =
Old Sep 17, 2013 | 10:46 PM
  #1500
Zfr is EFFICIENT up to 28psi, so why isnt anyone trying that power?
estimated on 93 425whp?
