Direct bolt-on turbo (ko4 replacement)
You talking about the 4 that ZZP offer now? I'm skeptical about them as of right now. And I don't think those alone would allow for me to use E anyways. I think regardless of the route I go I will need the 5th setup. We will see though. The Pwerks 5th injector is not like the ZZP, they actually tap into the manifold and weld a bung in for the injector
No, I really didn't NLS other than when I was at the track. It shattered third from doing waaayyyy tooo many third gear pulls. It was just a matter of time though. It held up strong with the zfr for the time it was in there. Zfr hasn't really caused me any problems. I'm actually getting the same MPGs as with stock turbo if not more.
Sent from my Samsung Galaxy S4 using CobaltSS
There's a ton of wheel spinning going on and it doesn't allow me to get super good times but I've managed a 12.89 @116 on street tires and some traps of 119-120. Its capable of low 12s-high 11s with slicks. Stock trans held up for about 6k miles with the turbo and Ky stage 3 clutch. I also beat my car, but I do maintain it pretty good and check everything regularly.
I'm still on 93. I only hit those high of traps when I rev'd to 7300 in second and third and then NLS 3-4. Not gonna lie though, when you NLS there the power is incredible. It just keeps flowing so smooth. Its almost way too good. Somewhat addicting...
However, I usually onlt use NLS when it's a pretty close race. LOL No need to stress anything out if I don't need to.
Speaking of which, were you on slicks too when you made that pass?
