do i need gm stage 1
I have an 08 lnf that I have running with 23 psi with the tune I have and I keep getting check engine lights for my map and temp sencers. I have the stock once in now and I remember hearing they only run up to 18 psi so do I need to get the gm stage one and get a retune or is there a way to just get better scencers
The stock 2bar sensor will work fine. I am running 23-24psi and it works just fine. The only reason to go with a 3bar is to run more than 25psi because the stock 2bar cannot accurately read more than 25psi.
I don't know what sort of agreement you signed when they tuned your car. But I am sure they would be willing to help you work out any issues.
Having said that, I think HOLDING at 23 lbs (not spike) is too much. I would probably go to Trifecta or HTP from here...unless the guy who did it knows what he did wrong.
