do i need a new map sensor if...?
Old May 20, 2009 | 11:11 PM
crackbunny's Avatar
Thumbs up do i need a new map sensor if...?
i have an 2009 cobalt ss/tc.
i know the hhr stage 1 comes with new map sensor and you need to get the tune from gm.
what if i buy a superchip tuner or buy an ecm from someone with a custom tune? do i need a new map? i know what and how a map works... but i dont see anyone including a map with a tuner or ecm.
also what exactly gets changed when you use a tuner? i was told the rpm limit and speed limiter get changed in addition to the new tune and a code reader. (superchip). what does hahn's tuner give me? how about the gm stage 1? i think 1st and 2nd gear rpm limit is now 7k and 3,4,5 are also raised to 7500k?
does the tune get rid of that little studder feeling when your at full acceleration and the ecm is limiting the power output of the motor. kinda feels like the wastegate is opening and closing really quick.
let me know everything and anything about these tunes. thanks guys
Old May 21, 2009 | 01:22 AM
shiftingloco310's Avatar
Idk what a tuner does but getting a custom tune is what i got and they just changed my afr and possibly timing. as for using a different map sensor i don't think it can be done w/o the gm tune only because they read different voltage and i don't think any tuning has unlocked that yet.
Old May 28, 2009 | 08:40 PM
crackbunny's Avatar
what does the tuner actually change? anyone?
Old May 29, 2009 | 12:09 PM
sponge14's Avatar
It depends. Most of your power is coming from up'ed boost levels. Trifecta is what I know since I have it, and they push about 22-23lbs. Vince (Trifecta) does other tweeks that I don't know about for reliability and to squeak out some more torque.
Old May 29, 2009 | 12:49 PM
revhigh18's Avatar
the tuner makes it slow
Old May 29, 2009 | 02:00 PM
proZak's Avatar
well I can tell you a hp tune will yield 343tq and 308 hp and runs 13.5 with a 106.8 trap in the quarter but I've blown 2 map sensors so I would say save your money and go with the gm kit
vid of my dyno...
http://www.youtube.com/watch?v=rBbVKB95Tn4
Old May 29, 2009 | 02:13 PM
mkriebs's Avatar
I can tell you that an HP tune will get me 12's soon, on an otherwise stock motor (no bolt ons).
I would go with an HP tune, but just be careful when you, or someone else tunes it, so you know you aren't hitting the 255 kpa MAP limit alot. Then it will last fine.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
