Does this look like an oil leak??
Old Feb 20, 2010 | 04:52 PM
Turbo'dSS's Avatar
So ive noticed a lil what looks like oil, on the passenger side of my engine. It looks to me like the valve cover gasket/seal might be bad. i have a couple spots where it looks like oil is coming out of. Is this normal? or do i have a problem? lol!
heres some pics, the first 2 are on the passenger side, and the third one is the front tward the pass side.
Old Feb 20, 2010 | 04:55 PM
chevysssc's Avatar
its common u can take it back to the dealer its covered
Old Feb 20, 2010 | 04:56 PM
Turbo'dSS's Avatar
well im tuned and stuff. im not sure if theyll warrenty it?
Old Feb 20, 2010 | 04:58 PM
ssyellow's Avatar
I believe I saw a "How to" to fix this problem. Check the how to section.
Old Feb 20, 2010 | 05:02 PM
chevysssc's Avatar
Read this http://www.dummies.com/how-to/conten...ty-intact.html
Old Feb 20, 2010 | 06:50 PM
Turbo'dSS's Avatar
i found the how to on it!! kinda sounds like whats goin on with mine. i might try it once weekend and see if that fixes it!
Old Feb 20, 2010 | 07:05 PM
rckrz6's Avatar
its not bad i wouldn't worry about it right now. mine has very small leaks also.
Old Feb 20, 2010 | 07:15 PM
Turbo'dSS's Avatar
well there is another spot in the front of the engine that i cant get a pic of that looks really bad! and the passenger side isnt a bad leak, cuz i cleaned it off last summer and its just now starting to look bad again. i figure if i get bored oneday ill go thru and try to fix it.
Old Feb 20, 2010 | 07:20 PM
tomj77's Avatar
there is no how to to fix it, ur gasket is most likely shot already like mine was, due to the valve cover bolts not being torqued to spec, i was tuned and took it back, and got a new gasket. the problem is is that gm didnt torque the valve cover bolts tight enough, its their fault, either take it in or get a new gasket or do it urself. in the mean time, tighten the bolts, mine tightened up quite a bit. now they dont move after i got it fixed.
Old Feb 20, 2010 | 07:42 PM
northvibe's Avatar
someone have the torq specs for the valve cover bolts?
Old Feb 20, 2010 | 07:49 PM
EcoTecDriver's Avatar
71ftlbs for the 2.0
89in-lbs for the 2.2-4
Old Feb 21, 2010 | 01:25 AM
Turbo'dSS's Avatar
Dang!! ill try this in the morn and see if they tighten up!! thanks man!
Old Feb 21, 2010 | 01:29 AM
krispy's Avatar
kinda looks like exhaust condensate, whatever is there isn't much, have you noticed any oil consumption?
Old Feb 21, 2010 | 01:32 AM
Turbo'dSS's Avatar
no not really. i didnt really check untill today though. lol! but the oil level is fine right now.
Old Feb 21, 2010 | 11:03 AM
tomj77's Avatar
its an oil leak, i had the same thing. if u clean it off and drive ur car hard for a bit u will notice a little oil running down there. its not enough to notice oil level change but enough to make things dirty and eventually blow the gasket
Old Feb 21, 2010 | 02:52 PM
jgfnova's Avatar
Originally Posted by EcoTecDriver
71ftlbs for the 2.0
I think it its 71 inlbs. for the 2.0
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
