downpipe gasket
downpipe gasket
Hey guys a have a clear image downpipe i jsut put on. the stock top part of the downpipe where there are the 4 bolts did not come with a gasket. So my question is where would i get the gasket if i actually need one.
Thanks
Thanks
There is not a gasket its acutaully a donut shapped gasket that sits inside the pipe where they bolt together you can re-use it will be fine just pull it out a little with a flat head screw driver. You wont find the Gasket in your local Parts store you will have to order it if you want it.
Here is the How To Guide to install your DP.
https://www.cobaltss.net/forums/how-...g-pics-160726/
Sep 28, 2015 12:51 PM
